查看: 16913|回复: 1
car模块柔性体仿真,求助
发表于 2006-3-31 10:54:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在做car模块第二个柔性体例子的时候,出现如下错误,不知道怎么修改,求大虾提示:
---- ERROR ----
Attempt = 1. No convergence after 25 iterations. Best iteration = 25.
Trying next attempt with a different set of statics parameters...
For the last attempted iteration the equation with the largest error
was PART ts11_static_load.TR_Front_Suspension_ger_lower_strut Error = 5386.5
The variable receiving the largest increment
was PART ts11_static_load.TR_Front_Suspension_rigflxcopypart_1 Delta = 9.810E+13
---- ERROR ----
Static equilibrium analysis has not been successful.
Restoring the input initial conditions...
---- ERROR ----
Initial Static Sim. Not Successful
Terminating ADAMS/Car usersubs...
ID = 1
发表于 2006-6-25 23:37:20 | 只看该作者
最好说一下做car模块第二个柔性体例子的简单内容和过程,然后再结合出错信息来解决问题!
GMT+8, 2025-4-22 16:48 , Processed in 0.020984 second(s), 11 queries , Gzip On, Redis On.
