! DO NOT write trail files across the network as it can create severe
! performance degradation.
!指定系统保存regen_backup模型的目录
regen_backup_directory $temp
!明确地使Pro/ENGINEER使用Temp目录,一步于再生模型实例。
use_temp_dir_for_inst YES
ang_dim_in_screen yes
axis_display no
!每步操作是否响铃提示:
bell no
button_name_in_help no
color on
color_ramp_size 16
color_windows all_windows
datum_display no
datum_point_display no
datum_point_symbol cross
datum_point_tag_display no
!default_font 8,MS Sans Serif,regular
depthcue_always no
!depthcue_value 50
dim_offscreen_limit 1.0
display shade
display_coordinate_sys no
display_full_object_path no
!!!!spin_with_notes no
silhouettes yes
edge_display_quality normal
flip_arrow_scale 2
fonts_size small
!如用专业绘图显卡,且是OpenGL 3D加速,使下面这行有效,否则注掉:
graphics opengl
hlr_for_quilts yes
lods_enabled no
mesh_spline_surf no
number_user_colors 16
number_wireframe_colors 16
orientation trimetric
save_display yes
save_full_top_level_display no
save_triangles_flag no
!下面菜单宽度默认为8,中英界面最好设成13,范围为8到20,超出即认为设为8:
set_menu_width 11
set_zero_curvature_color no
shade_surface_feat no
shade_windows all_windows
shade_with CURVES
show_shaded_edges no
smooth_lods no
!确定是否显示旋转中心符号。
spin_center_display no
spin_control DRAG
spin_rate_zoom_sensitive yes
spin_with_part_entities yes
spin_with_silhouettes yes
system_background_color 0 0 0
tangent_edge_display solid
thermo_position_hint no_window_overlap
visible_message_lines 3
! Control size of the window by either one of the following config options
!设定窗口为满屏
windows_scale 1
!设定菜单空间为1个菜单的空间
reserved_menu_space 1
! 用户界面设定(通用操用)User Interface (General Behavior)
!控制对话框中的弹出是帮助。
enable_popup_help yes
iconify_entire_pro yes
info_output_mode CHOOSE
kbd_cmd_abbreviation off
keep_info_datums yes
logical_objects yes
measure_sig_figures 6
menu_show_instances no
model_tree_start yes
nt_cache_dirs yes
pick_aperture_radius 7
prompt_on_erase_not_disp no
!prompt_on_exit no
prompt_on_exit yes
query_bin_start yes
retain_display_memory yes
select_on_dtm_edges all_modes
set_trail_single_step no
start_appmgr yes
summary_help yes
!trail_delay 1
visible_mapkeys no
allow_anatomic_features yes
TOLERANCE_CLASS fine
! 文件编辑相关设定File Editors:
! Test by typing the command in an MS Dos command window.
! If the command does not work, verify the command to
! access the editor with your hardware type.
pro_editor_command notepad
drawing_file_editor editor
protable_in_background no
relation_file_editor editor
!语言界面设定 Language Interface
menu_translation both
!上面中英对照值设为both,英文为No,全中文件为YES
lang_propagate yes
!上面为装了多于2种或以上第3方语言时请设为YES
help_translation yes
msg_translation yes
dialog_translation yes
!上面3项为MENU提示、显示信息和对话框,设为NO为英文
!图层设定 Layers
!默认图层 Default Layers
! The naming convention shown here for layers provides
! a way to organize your layers in a specific order. Pro
! sorts layers in alphanumeric order. As new layers are
! created, they will be added to the bottom of the list if
! they begin with an "alpha" character. They will be added
! to the top of the list if they begin with "0_". In addition,
! if you want to add new layers for a group of items, you can
! make them appear as indented layers. For example:
! 01_ALL_PLANES
! 01___DEF_PLANES
! 01___ANG_PLANE
! 02_ALL_CSYS
! 02___DEF_CSYS
! 03_ALL_AXES
! 03___HOLE_AXES
!以下如要自动建立图层,请去掉前面的叹号
! 草绘相关设定Sketcher
sketcher_dec_places 3
sketcher_animated_modify yes
sketcher_disp_constraints yes
sketcher_disp_dimensions yes
sketcher_disp_vertices yes
sketcher_overview_alert no
SKETCHER_README_ALERT NO
sketcher_readme_button no
sketcher_undo_stack_limit 200
sketcher_starts_in_2d yes
sketcher_intent_manager yes
!实体模式下 Part Mode
allow_old_style_round no
allow_udf_style_cosm_threads no
! 工程图模式Drawing Mode
allow_move_in_dtl_move yes
allow_move_view_with_move yes
allow_rfs_default_gtols_always yes
auto_associate_dimensions yes
auto_regen_views yes
create_drawing_dims_only yes
create_fraction_dim no
!default_draw_scale 0.01
display_dwg_tol_tags yes
disp_trimetric_dwg_mode_view yes
draw_models_read_only no
draw_points_in_model_units no
!drawing_view_origin_csys no
dwg_select_across_pick_box no
force_wireframe_in_drawings no
gtol_dim_placement under_value
highlight_new_dims yes
highlight_erased_dwg_views no
make_parameters_from_fmt_tables no
make_proj_view_notes no
variable_plots_in_inches no
dxf_out_drawing_scale yes
!参考尺寸在括号内设yes,No为在后加REF :
parenthesize_ref_dim Yes
pick_chain_tangent_only no
rename_drawings_with_object both
selection_of_removed_entities no
switch_dims_for_notes yes
sym_leader_orient_move_text no
symbol_palette_input yes
todays_date_note_format %yyyy/%mm/%dd
variant_drawing_item_sizes no
Projection_type first_angle
drawing_units mm
!单位设定(当不选用模板时起作用)
! Unit and Tolerance Setup
! Change to UNIT_MM if working in millimeters
!pro_unit_length UNIT_INCH
!PRO_UNIT_LENGTH UNIT_FOOT
pro_unit_length UNIT_MM
!PRO_UNIT_LENGTH UNIT_CM
!PRO_UNIT_LENGTH UNIT_M
! Change to UNIT_KILOGRAM if working in kilograms.
!PRO_UNIT_MASS UNIT_OUNCE
!pro_unit_mass UNIT_POUND
!PRO_UNIT_MASS UNIT_TON
pro_unit_mass UNIT_GRAM
!PRO_UNIT_MASS UNIT_KILOGRAM
!PRO_UNIT_MASS UNIT_TONNE
! Change to ANG_MIN or ANG_SEC if desired. ANG_DEG will show decimal degrees.
ang_units ANG_DEG
! Number of significant figures given when using #info;#measure
!默认单位系统:mmns 毫米:
pro_unit_sys mmns
! Set to the most common tolerance type which appears on your drawings.
! Note: Tolerance display on drawings (on or off) is controlled
! by the drawing setup (.dtl) file, accessed ONLY at drawing creation
! or when explicitly retrieved or modified. With "tol_display" set to
! "yes" in the .dtl file, dimensions with their "format" changed to
! other than "nominal" will appear with their tolerance values.
! Drawing setup option values are stored with the drawing.
! Note: The configuration option "tol_display" controls display of
! tolerances in part and assembly windows, not in drawing windows.
tolerance_standard ISO
!tol_mode NOMINAL
tol_mode PLUSMINUS
tol_display no
! Set linear and angular tolerances based on your company standard.
! Remove the comment character ("!") from the settings desired
! Examples: LINEAR_TOL 2 0.03 => 3.01 +- .03
!LINEAR_TOL 3 0.005 => 3.013 +- .005
!LINEAR_TOL 3 0.010 => 3.013 +- .010
! General File Managment
instance_search_exhaustive no
propagate_change_to_parents no
read_famtab_file_on_retrieve no
regen_backup_using_disk no
save_instance_accelerator none
save_modified_draw_models_only no
save_objects changed
save_unchanged_pdm_object as_ref
warn_for_unlocked_obj no
! Pro/PIPING
pipe_solid_centerline no
!pipe_3d_bend_theor_int_pts yes
pipe_3d_bend_theor_int_pts no
! webpub options
www_add_aux_frame NO
www_export_geometry_as JPG_VRML
www_multiple_views ALL
www_tree_location in
! vrml options
vrml_anchor_url no
vrml_background_color no
vrml_explode_lines yes
vrml_export_resolution medium
vrml_file_duplicate_material yes
vrml_multiple_views all
vrml_simprep_export yes
vrml_parameters designated
!==快捷键 MAPKEYS ==
! The mapkeys included have been created to automate standard functions.
! Review the mapkeys listed below and delete ones that you will not use.
! Create mapkeys to automate functions you will do frequently.
! GENERAL MAPKEYS
! The following mapkey creates all Primary Views based off of a Front view
! Define Views
! Orient to what you desire to be the Front View
mapkey @views @MAPKEY_NAMEDefine Standard Views;\
mapkey(continued) @MAPKEY_LABELDefine Standard Views;%@def_front;%@def_right;%@def_top;\
mapkey(continued) %@def_left;%@def_bottom;%@def_back;%@def_iso;%vd;
! SKETCHER
! Most of these mapkeys are obsolete when
! Intent Manager is used
mapkey ss #Sketch;
