查看: 16333|回复: 3
[讨论] 请ugnx4.0.0.25补丁怎样用
发表于 2006-4-6 13:54:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
UGNX4.0.0.25补丁怎样用,我把文件夹复制到安装目录下,但是UG就打不开
发表于 2006-4-6 16:33:29 | 只看该作者
To use this update, change to the directory where you extracted the nx-4.0.0.25.mp01.tar.Z distribution file, make sure the entire set of new patch files have execute access, then execute the “ugs_update” script.
After the MP update has run successfully, the following identifying text will be written into the system log of every NX session:
"NX 4.0.0.25 MP 1, 31Jan06. See Maintenance Pack letter for detailed list of fixes."
发表于 2006-4-6 21:19:46 | 只看该作者
可不可用中文,我不懂英文
发表于 2006-4-7 15:04:34 | 只看该作者
你先要安装好nx-4.0.0.25这个版本,再点击ugnx4.0.0.25补丁文件夹里的ugs_update.bat这个文件就会自动安装的
GMT+8, 2025-8-1 15:23 , Processed in 0.022062 second(s), 12 queries , Gzip On, Redis On.
