查看: 17083|回复: 0
关于UF_CURVE_section_from_planes ()的问题
发表于 2006-4-7 21:26:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
怎样用
extern UFUNEXPORT int UF_CURVE_section_from_planes (
    UF_CURVE_section_general_data_p_t    general_data,  /* <I> Data provided
                                                          by the user to to be
                                                          used in creating the
                                                          section curve feature.
    UF_CURVE_section_planes_data_p_t    planes_data,    /*<I>  Sectioning planes
                                                          and datum planes.*/
    tag_t    *section_curves      /* <O>
                  Feature tag, if general_data->associate is 1, or
                  Group tag of section curves if general_data->associate is 0
                                       and general_data->grouping is 0, or
                  Group tag of groups of curves if general_data->associate is 0
                                       and general_data->grouping is 1  */
就是对第一二个 参数不会设置,怎样调用UF_CURVE_section_general_data_p_t,尤其对
UF_CURVE_section_general_data_s中的tag_t *objects 怎样设置
GMT+8, 2025-4-23 11:58 , Processed in 0.021524 second(s), 11 queries , Gzip On, Redis On.
