查看: 15719|回复: 1
关于animation
发表于 2003-2-20 20:54:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问谁知道animation模块如何用,有没有相关的资料呢?
发表于 2003-2-21 08:26:11 | 只看该作者
About Animation
Use the Application > Animation command to invoke the Design Animation option. With Design Animation, you can coordinate the components of an animation sequence and play back an animation.
When you select this command, a timeline window appears below the graphics window, and a toolbar appears below the Pro/ENGINEER toolbar. You can run, create, and manage your animation using the menu commands, the toolbar buttons, or the timeline window.
You can use Design Animation to do the following:
·  Visualize your assembly's operation. If you have the concept, but have not defined the mechanics, you can drag bodies to different positions and take snapshots to create an animation.
·  Create an assembly or disassembly sequence animation of your model.
·  Create a maintenance sequence, a short animation of steps to take to instruct a user in how to repair or build a product.
For an introduction and overview of the Design Animation module, and for typical steps to take to create an animation, see the Design Animation Concepts Guide online document.
GMT+8, 2025-4-4 05:43 , Processed in 0.050728 second(s), 12 queries , Gzip On, Redis On.
