查看: 16547|回复: 1
[求助] 请问这个WARNING 到底是指哪里出问题?
发表于 2006-4-17 21:32:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我正在做机械手的仿真 用simulate script后出现下面的对话框 到底是什么问题?
WARNING:    The markers for JOINT doyido.JOINT_1 are not initially coincident.
   The relative displacement between the markers, expressed in the
   J marker coordinate frame is:
   Delta X = -4.13041E-02   Delta Y = -7.00511E-02   Delta Z = 1.38261E-07.
WARNING:    The markers for JOINT doyido.JOINT_2 are not initially coincident.
   Delta X = 4.13040E-02   Delta Y = -7.00510E-02   Delta Z = -1.38261E-07.
WARNING:    Initial displacement of MOTION doyido.MOTION_1 differs from that of
   JOINT doyido.JOINT_1, on which it is located, by -9.8365 degrees.
WARNING:    Initial displacement of MOTION doyido.MOTION_2 differs from that of
   JOINT doyido.JOINT_2, on which it is located, by 9.8365 degrees.
怎么可以解决?
发表于 2006-4-19 08:22:57 | 只看该作者
先检查doyido.JOINT_1和doyido.JOINT_2,按提示,是定义joint的两个marker初始位置不重合。
GMT+8, 2025-4-22 23:02 , Processed in 0.020547 second(s), 11 queries , Gzip On, Redis On.
