查看: 16297|回复: 0
[求助] ㄧ個錯誤訊息~~這是什麼意思
发表于 2006-4-23 22:45:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
|  Memory Allocated for Run  (Actual usage may be less)        |
  Data Type      Kwords  Words/Node  Words/Elem     Kbytes  Bytes/Node
  Real         546116.4      681.94      129.78  2133267.0     2727.77
  Integer      147993.7      184.80       35.17   578100.2      739.21
  Character      2428.8        3.03        0.58     2371.9        3.03
  Logical          40.0        0.05        0.01      156.2        0.20
  Double          624.5        0.78        0.15     4878.9        6.24
| ERROR #001100279 has occurred in subroutine ErrAction.  |
| Message:        |
|         *** Run-time memory allocation error ***                    |
| Not enough free memory is currently available on the system.       |
|    Could not allocate requested memory - exiting!                  |
|                An error has occurred in cfx5solve:                                |
| The CFX-5 solver exited with return code 2.   No results file has  |
| been created.        |
End of solution stage.
This run of the CFX-5 Solver has finished.
GMT+8, 2025-4-20 08:15 , Processed in 0.020002 second(s), 12 queries , Gzip On, Redis On.
