查看: 18362|回复: 1
[求助] 毕业设计紧急求助:怎么用UG找质心!谢谢大侠们!
发表于 2006-4-30 16:10:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
毕业设计紧急求助:怎么用UG找质心!谢谢大侠们!毕业设计紧急求助:怎么用UG找质心!谢谢大侠们!
发表于 2006-5-1 09:31:21 | 只看该作者
测量质量属性
显示的质量属性值
体积                            = 643828.612304010 mm^3
面积                            = 54820.948436344 mm^2
质量                            = 5.041589219 kg
重量                            = 49.441145517 N
回转半径                        = 54.252530398 mm
质心                            = -3.826486597, -0.000433212, 36.008021285 mm
详细的质量属性
使用精度计算的分析 0.990000000
信息单位     in - Area
密度                  = 0.000007831
质量                  = 5.041592466
一阶矩
Mxc, Myc, Mzc         = -19.291585998, -0.002184079, 181.537768842
质心
Xcbar, Ycbar, Zcbar   = -3.826486597, -0.000433212, 36.008021285
惯性矩(工作坐标)
Ixxw, Iyyw, Izzw      = 11860.512927972, 16880.484032252, 14158.484562572
惯性矩(质心)
Ixx, Iyy, Izz         = 5323.697082470, 10269.849192448, 14084.665566378
惯性矩(球坐标)
I                     = 14839.105920648
惯性积(工作坐标)
Pyzw, Pxzw, Pxyw      = -0.164549542, -514.062246365, -1.101686656
惯性积(质心)
Pyz, Pxz, Pxy         = -0.085905182, 180.589592879, -1.110044004
回转半径(工作坐标)
Rxgw, Rygw, Rzgw      = 48.502918007, 57.864016949, 52.993733499
回转半径(质心)
Rxg, Ryg, Rzg         = 32.495468270, 45.133411802, 52.855404551
回转半径(球坐标)
R                     = 54.252530398
主轴
Xp(X), Xp(Y), Xp(Z)   = -0.020599845, 0.000016504, 0.999787801
Yp(X), Yp(Y), Yp(Z)   = 0.000224859, 0.999999975, -0.000011874
Zp(X), Zp(Y), Zp(Z)   = -0.999787775, 0.000224567, -0.020599848
主惯性矩
Ixxp, Iyyp, Izzp      = 14088.386475211, 10269.849441032, 5319.975925053
误差估计
体积                            = 1265.739836478
面积                            = 77.263383004
质量                            = 0.009911558
惯性矩(球坐标)                = 0.182518097
质心                            = 0.884064456, 0.921986605, 1.278886479
惯性矩(工作坐标)              = 149.958532105, 143.048484328, 63.798446031
惯性积(工作坐标)              = 73.733620207, 37.006737516, 41.899825456
GMT+8, 2025-4-27 12:54 , Processed in 0.024152 second(s), 13 queries , Gzip On, Redis On.
