查看: 15329|回复: 1
grip开发的一个问题
发表于 2006-5-9 09:36:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
通过给定点的三维坐标生成B样条曲面,请教文件“COORDS” 放到那个目录下阿,我的程序编译能通过,只是在UG里面执行的时候出现错误,程序如下:
Through Points Example
This example program creates a multi-patch surface through the point coordinates contained in the text file "COORDS". The program prompts the user to enter the desired number of rows for the surface. The program then places the same number of points into each row and creates the surface through them.
$$  Declarations
    NUMBER/ROW(500),NUM(3)
    ENTITY/P(200), BS
$$ Geometry Definition
    L10:
    PARAM/'ENTER # of rows','# OF ROWS',R,RESP
    JUMP/L10:,TERM:,,RESP
    DOPEN
    FETCH/TXT,1,'COORDS'
    RESET/1
    L20:
    READ/1,IFEND,END:,NUM
    K=K+1
    P(K)=POINT/NUM
    JUMP/L20:
    END:
    A=K/R
    L30:
    J=J+1
    ROW(J)=A
    IF/J==R,JUMP/CONT:
    JUMP/L30:
    CONT:
$$ B-Surface Definition
    BS=BSURF/P(1..K),ROW(1..R)
    TERM:HALT
执行时出现的错误是说为“coods”未找到,文件中坐标点是什么格式阿?应该把它放到那个目录下呢?恳请那位前辈帮忙
发表于 2006-5-9 17:56:20 | 只看该作者
    ENTITY/P(200), BS
    L10:
    DOPEN
    FETCH/TXT,1,'c:\COORDS.dat'  $$example
GMT+8, 2025-2-1 10:10 , Processed in 0.022026 second(s), 10 queries , Gzip On, Redis On.
