查看: 16176|回复: 2
[原创] 我做档板式冷却时出现的问题,请大家帮帮我,看看是什么地方出错了?
发表于 2006-5-29 10:00:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下面是分析出来的错误,不知是什么原因,请大家帮帮我,看看是什么地方出错了,做档板式冷却时应该注意什么样的问题?
** ERROR 702340 ** Node   56234  is only connected to one baffle element. Baffles
                   need to be modeled with elements representing both the
                   upward section and the downward section in order to obtain
                   unique heat transfer coefficents for both sections.
** ERROR 702340 ** Node   56244  is only connected to one baffle element. Baffles
** WARNING 702280 ** Circuit has more than one outlet node. Using
                     node   56266
** ERROR 702340 ** Node   56229  is only connected to one baffle element. Baffles
** ERROR 702340 ** Node   56239  is only connected to one baffle element. Baffles
                     node   56278
分析检查发现 4 个错误和 2 个警告
发表于 2006-5-29 13:35:27 | 只看该作者
隔板水路没有连接好。另外,水路中发现多个出水口。
发表于 2006-6-2 11:44:34 | 只看该作者
谢谢版主,问题已解决.
GMT+8, 2025-1-30 03:57 , Processed in 0.020644 second(s), 11 queries , Gzip On, Redis On.
