查看: 16316|回复: 1
[求助] 选多个相邻曲面,在提出其最外轮廓线用不了?
发表于 2006-6-1 10:58:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                   CIM E 中讲
                  You can also Choose a surface (manual option), and all outer surface edges will be selected as a closed contour.
                 If you choose two or more adjoining surfaces, the contour that defines the outer boundary of all surfaces will be selected. Example
                  为何我选择不包括垂直曲面,能显示多个相邻曲面并提出其最外轮廓线,但有时用不了?,出现端点错误.
                  为何包括垂直曲面(直身面)选择不了!!!!
                  谢谢指教!!!
                       附图
发表于 2006-7-19 13:53:49 | 只看该作者
很难吗
GMT+8, 2025-4-29 00:10 , Processed in 0.021951 second(s), 10 queries , Gzip On, Redis On.
