查看: 18391|回复: 11
[分享] 模架参数1.2版
发表于 2006-6-6 18:58:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
欢迎高手校对里面参数解释,请提出宝贵意见,在此感谢您光临!
[ 本帖最后由 湖一刀 于 2006-6-10 12:18 编辑 ]
发表于 2006-6-7 09:11:53 | 只看该作者
下了支持你以下
发表于 2006-6-7 20:34:54 | 只看该作者
有局部改进,请下免顶,这段时间较忙,以后会继续修全MW库参数…… AP_off        A-Plate offset for parting gap (redundant in universal)        mold_l        Mold length in X axis
BCP_w        Bottom clamp plate width        mold_w        Mold width in Y axis
BCP_h        Bottom clamp plate thickness        mv        Moldbase levels of moving (core) plates
BP_off        B-Plate offset for parting gap (redundant in universal)        rb        Moldbase levels of reverse ejection box plates
CP_w        Spacer plate width        ret_pin        Return pin
EB        Ejector box plates thicknesses        ret_sprg        Return spring (on return pin)
EJA        Ejector retainer plate thickness (redundant in universal)        rp        Moldbase levels of reverse ejector plates
EJB_off        Ejector push plate level (used for ej pins)        scr        Screws
EJP_w        Ejector plate width        scr_bi        Screw to attach b insert
EP        Ejector plate thicknesses        scr_a        Clamp-plate to A-plate screw
EP_h        Ejector plate thicknesses        scr_ai        Cavity insert screw
EP_r_h        Ejector retainer plate thickness (redundant in universal)        scr_b        Core-plate to EJ housing screws
FX        Fixed (cavity) plates thicknesses        scr_bi        Core insert screw
IN        Injection plates thicknesses        scr_c        EJ support plate to EJ retainer plate screws
MV        Moving (core) plates thicknesses        scr_asy1        Assembly screw attaches B plate to support plate
RB        Reverse ejection box plates thicknesses        scr_asy2        Assembly screw holds EJ plates against return springs
RP        Reverse ejection plates thicknesses        scr_strpr        Screw attaching stripper plate to return pins
SP        Support plate thicknesses (redundant in universal)        shldr_a        Shoulder screw (head-up) from A-clamp plate to X plate
SP_h        Support plate thicknesses (redundant in universal)        shldr_b        Shoulder screw (head-down) from A plate to X plate
TCP_h        Top clamp plate thickness        shldr_c        Shoulder screw (head-down) from B plate to A plate
cfg        Plate configuration (see plate configuration sheet)        spr        Sprue bushing
dwl_t_a        Tubular dowel to align A clamp plate with A plate        spt        Support columns or pillars
dwl_t_b        Tubular dowel to align B plate with EJ housing        st        Moldbase levels of stripper plates
dwl_a1        Dowel to align A clamp plate with A plate        stp        Stop buttons
dwl_b1        Dowel to align B plate to support plate        strp_pin        Stripper guide pin
dwl_b2        Dowel to align support plate to EJ rails        strp_bsh        Stripper guide bushing
dwl_b3        Dowel to align EJ rails to EJ clamp plate
eb        Moldbase levels of ejection box plates
ep        Moldbase levels of ejector plates
fx        Moldbase levels of fixed (cavity) plates
gd_pin        Guide pin
gd_bsh        Guide bushing cavity plate (A series mold)
gd_bsh_a1        Guide bushing for cavity plate (three plate mold)
gd_bsh_a2        Guide bushing for AX plate (three plate mold)
gd_bsh_b1        Guide bushing for B series mold
gej        Guided ejection
in        Moldbase levels of injection plates
ko        Knock out (holes in EJ clamp plate)
loc        Parting locks
[ 本帖最后由 湖一刀 于 2006-6-7 20:40 编辑 ]
发表于 2006-6-8 09:08:04 | 只看该作者
楼主有联系方式吗 留给兄弟一个
发表于 2006-7-6 16:22:21 | 只看该作者
顶啊,以前我也研究了好久。被简写的几个字母搞得头晕脑胀的。
发表于 2006-7-12 10:03:05 | 只看该作者
谢谢啊
发表于 2009-11-2 23:48:51 | 只看该作者
支持
谢谢啊
发表于 2009-11-2 23:56:19 | 只看该作者
我下载看看,要是可以任意制定非标模架就好了
发表于 2009-11-3 20:10:12 | 只看该作者
谢谢,望有高手能将所有的问题全部处理掉.
发表于 2009-11-5 19:26:53 | 只看该作者
ddddddddddddd 1# 湖一刀 d
GMT+8, 2025-4-22 04:18 , Processed in 0.027973 second(s), 13 queries , Gzip On, Redis On.
