查看: 15591|回复: 2
【求助】
发表于 2003-3-6 19:47:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教各位,如何击活UGNX中FORMAT菜单下的数据库属性这一选项?在此先谢谢各位.
发表于 2003-3-7 11:55:19 | 只看该作者
UGNX_HELP!
This section describes Database Attributes, and explains how to access and use them in Unigraphics NX. For additional information regarding how to configure them in an iMAN database, go to System Administration.
The Database Attributes feature is only available if enabled by your Unigraphics NX system administrator. It can be turned on and off by setting an environment variable, or a preference in the .ugii_env file (on UNIX) or the ugii.env file (on Windows NT). For additional information, go to What Are Database Attributes?.
发表于 2007-7-3 21:24:53 | 只看该作者
请问在UG4.0中,如何激活 FORMAT下的database attributes,上面说设置环境变量,环境变量是什么,请说明白一点是什么,好吗?
GMT+8, 2025-4-22 23:00 , Processed in 0.023911 second(s), 13 queries , Gzip On, Redis On.
