查看: 16543|回复: 4
[求助] 关联参数
发表于 2006-6-29 17:45:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位兄弟是否记得Cimatron it版中,设置NC下关联参数那个文件在哪里?比方tldi*0.5这些参数.以前用过,一下忘记啦!请哥们帮帮手!江湖救急!!!![/siz
e]
发表于 2006-6-30 10:07:24 | 只看该作者
IT很久没用过了,不过E里的帮助文件中有一个比较详尽的变量表.
基本上跟IT是一样的.
发表于 2006-6-30 10:10:45 | 只看该作者
不懂,顶楼主。
发表于 2006-6-30 10:24:11 | 只看该作者
大致就是这些吧,不知你要的是不是这个
3D Side Step = sist3d
Absolute Z, Delta Retract = iaclr
Chamfer diameter = cdia
Check / Part 2 surface offset = csof
Check / Part2 surface tolerance =  csto
Clear height = clear
Clear length = crln
Contour approach arc radius = arcra
Contour approach length = cappr
Contour offset (Rough) = rouof
Contour offset rough (between layers) = orouof
Contour retract length = cretr
Contour retract radius = arcrr
Contour tolerancr = ctol
Corner radius = crrd
Cutter diameter =  tldi
Cutting length =  ctln
Cutter life =  lfln
Decrease = dcrs
Delta init = iiclr
Delta retract = iaclr
Down Step = dnst
DZ/Feed Start = dlzu
Effective Coverage Radius = effcov
Entry offset = eoff
Fixed Vertical Step / Max. Vertical Step = mxclmdsr
General contour offset = goff
Gauge length = guln
Horizontal Step = clss
Incremental clear = iiclr
Leading angle = ldang
Lift (Clean Between Passes / Clean Ridges Method = Trochoidal) =  lift
Margin For Pre-Final Pass = mrwdt
Max. 2D Distance = blmx2dst
Max. Down Step (ReRough) - specific to Cleanup = clmds
Max. Entry Length = mwayl
Max. Ramp Radius = rmpr
Max. Step Angle = msang
Max. Triangle Length = mxtrln
Max. Vertical Step = blmxvrst
Max. Z of box bounding all surfaces and solids in the procedure UCS. = maxpz
Min. 2D Side Step = mnsist
Min. 3D Side Step = mnsist
Min. Narrow Area Width in Finish - (Clean Between Passes) = minwdtf
Min. Narrow Area Width in Rough - (Clean Between Passes) = minwdt
Min. Plunge Diameter =  pldia
Min. Plunge Size =  mnpls
Min. Radius =  mrad
Min. Side Step (between layers) = ominst
Min. Vertical Step =  blmnxvrst
Min Z of box bounding all surfaces and solids in the procedure UCS. =  minpz
Offset (ReRough) =  rroff
Orbit Planar Gap =  porbt
Overlap Distance (Layers Connection - Finish Mill All) =  Icod
Part Surfaces Floor Offset =  vsoff
Preferred 5X Lead Angle =  plean
Preferred Approach Radius (Layers Connection - Finish Mill All) =  lcar
Preferred Corner Radius =  herad
Preferred Retract Radius (Layers Connection - Finish Mill All) =  lcrr
Previous Cutter Offset (Cleanup) =  qcovrlpl
Previous cutter offset =  ovrlpl
Ramp angle =  rang
ReRough Offset - specific to Cleanup =  rroffs
Round for Stretch =  stround
Scallop =  sclp
Scallop (between layers) =  osclp
Shift Distance (On Surface) - (Layers Connection - Finish Mill All) =  lcsds
Shift Distance (Tangent) - (Layers Connection - Finish Mill All) =  lcsdt
Shift I =  shfti
Shift J =  shftj
Side step =  sist
Side Step =  clmssr
Side Step (Machine Between Layers) =  blclmssr
Side step (between layers) =  osist
Side Step (ReRough) - specific to Cleanup =  clmss
Slope angle (between layers) =  slpang
Spark Gap 3D Offset =  spgap
Step =  step
Stock Width =  swid
Surface offset =  soff
Surface tolerance =  stol
Surface approach length =  sappr
Surface approach arc radius =  arcra
Taper angle =  tpan
Tilting angle =  tlta
Tool diameter =  tldi
Trochoidal Pitch =  rtrpitch
Vertical Step =  clds
Walls offset (between layers) =  wallof
Z Bottom =  zdwn
Z Margin (Skip Planes) =  zmarg
Z Top =  zupp
发表于 2006-7-4 19:09:21 | 只看该作者
不是这个!就是关系式,这个文件在哪里?应该就在一个文件夹下面吧!谢谢啦!
GMT+8, 2025-4-28 06:15 , Processed in 0.021609 second(s), 11 queries , Gzip On, Redis On.
