查看: 18951|回复: 18
【求助】如何將目錄下各子目錄Post成個別的刀路??
发表于 2003-3-9 14:08:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
見附圖,如何只選取Program的目錄,可以將底下四個目錄Post成四條刀路.
在PostBuilder有Group Output的方式,可是做不出來,有哪位高人用過的可否說明!!!!
发表于 2003-3-9 14:20:05 | 只看该作者
注意刀路的连续性
发表于 2003-3-9 15:03:44 | 只看该作者
一起学习学习
看了看帮助
Generate Group Output
This option allows you to define how your post handles groups. You can organize your operations into groups in Unigraphics NX to create more than one NC program in a part file. The system considers each group as one program and you should considered it as one complete NC tape. The default setting for this option is OFF. You should not use this option unless you want to postprocess more than one NC program at a time.
If you select more than one group and you have this option turned ON you get one file that contains all of the groups (programs) that you have selected. The system names this file my_file.ptp. You also get an NC program file for each group or program you have selected. The system names them my_file_group.ptp. If your base file name is "nctape" and your group or program name is "O1234" then the name of your file will be nctape_O1234.ptp.
Do not mix operations in groups with operations outside of groups when you have set the group output to on. This causes unpredictable output. When you set the group output to off, you only get a single NC output file called my_file.ptp. The system outputs all operations in any selected group in a single NC file. The system ignores all group organization.
You can use the name of the group or program in Unigraphics NX as the program name in the Start of Program event. The system passes this to you as the variable name mom_group_name.
发表于 2003-3-9 15:29:07 | 只看该作者
大致翻译了一下,不多的请指出
这个选项允许你定义如何后处理组.在ug里,你可以在一个文件里组织你的operation到group里以创建更多的 nc program . 系统认为每个group是一个program而且你也要考虑这个组是一个完整的 nc tape(?)
缺省的设置是off.除非你想一次处理多个nc program,否则不要用这个选项.
如果你选择多个group而且这个选项是on,你会得到一个包括所有你选择的groups (programs)的文件.系统把这个文件命名为my_file.ptp.你也会得到每个你选择的group or program的数控程序.系统命名为my_file_group.ptp.如果你的base file name是"nctape"而且你的组名是"O1234",那么你的文件名就是nctape_O1234.ptp.
当你这个选项为on时,不要把组内和组外的操作混合.这会导致不可预知的输出.
当你这个选项为off时,你只会得到一个数控程序my_file.ptp.系统会把所以的选择的操作输出到一个数控文件.系统忽略所有的组.
你可以用group or program的名字作为程序名,在start of program 事件里修改.
系统会在变量mom_group_name传达给你.
发表于 2003-3-9 15:31:09 | 只看该作者
实践一下.
选上这个选项
发表于 2003-3-9 15:37:32 | 只看该作者
组织group,选择nc program
输出.
发表于 2003-3-9 15:38:22 | 只看该作者
得到如帮助所说的6个文件.
发表于 2003-3-10 13:56:14 | 只看该作者
啊!真是高!
发表于 2003-3-10 18:03:51 | 只看该作者
Bravo!!!多謝版主指導............
发表于 2006-6-2 10:27:47 | 只看该作者
多谢版主指导
GMT+8, 2025-2-24 07:30 , Processed in 0.023967 second(s), 10 queries , Gzip On, Redis On.
