查看: 16644|回复: 4
[讨论] PW2.0或PW3.0+EMX再生模架容易跳机
发表于 2006-7-15 17:04:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PW2.0或PW3.0+EMX4。1再生模架容易跳机,不知是什么回事,所以不敢用野火来设计模具,郁闷.
还是P2001+EMX稳定,不知各位同行有否这种现象。
[ 本帖最后由 yaoyongyu 于 2006-7-15 17:06 编辑 ]
发表于 2006-7-15 23:13:40 | 只看该作者
不会呀,用WILDFIRE2.0用EMX4.0做开模具模拟的时候就会死机。但4.1就不会,WILDFIRE3.0用4.1也没事!
发表于 2006-7-16 08:16:15 | 只看该作者
真的不行呀,开好模架时没事,但修改模架尺寸,或者开框,或者在回针上装弹簧,都会出现再生失败或者干脆跳机。闷。
    现在只能在PE2001里做好3D,在野火里标数了。野火标数还是爽的,特别是3。0
发表于 2006-7-30 17:26:43 | 只看该作者
你用的EMX是M150的版本吧
他的那个螺钉孔 PTC已经解决了
你到网上去下载有个 M350的版本的EMX
这个和PRO/E 无关
是PTC自己的问题!~~
发表于 2006-8-10 10:57:27 | 只看该作者
Installation:
As an extension pack of Pro/E, You should install Pro/ENGINEER WILFRE2.0 or WILDFIRE 3.0 before you install the EMX5.0  F000 extension pack of pro/E and ensure your pro/e license includes the #192 feature< Feature Expert_Moldbase(192)> of pro/e. Of course, prior to rlz lic gen of Pro/e for WILDFIRE2.0 and 3.0 by ZWT includes the feature.
Attention:
   The EMX 5.0 no longer supports lower version of pro/E, the Pro/ENGINEER 2001 and WILFIRE can't run it enven if you have the right lic!
OK, if the above reday, let's go now:
run setup, choose all installation options and the right language which you need and choose an installing location, e.g. c:\ptc\emx5.0 , then Press Next button till finish.
Copy the following file under the installed emx5.0.F000 directory, e.g.:
c:\ptc\emx5.0\text\config.pro
  and paste it into the following installed directory of pro/e:
  e.g. for wildfire 2.0, please paste it into here:
       \proeWildfire 2.0\text
e.g. for wildfire 3.0, please paste it into here:
       \proeWildfire 3.0\text
GMT+8, 2025-3-11 04:09 , Processed in 0.022231 second(s), 10 queries , Gzip On, Redis On.
