查看: 29983|回复: 50
[原创] config.pro和工程图配置选项之必杀技,(不看会后悔)
发表于 2006-7-17 17:54:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
很长时间没
[ 本帖最后由 fishyu205 于 2006-8-1 20:49 编辑 ]
发表于 2006-7-17 18:03:07 | 只看该作者
接下来我们再来讨论一下工程图配置文件选项detail.dtl,名字可能和你们不同
复制下来既可使用
1.控制文本的选项        值是我的设置,符合国标的,我就是用它来出图的
drawing_text_height     3.500000
text_thickness          0.000000
text_width_factor       0.800000
2控制视图和注释选项
broken_view_offset 1.000000
create_area_unfold_segmented NO
def_view_text_height 3.000000
def_view_text_thickness 0.000000
detail_circle_line_style PHANTOMFONT
detail_circle_note_text DEFAULT
detail_view_circle ON
half_view_line SOLID
model_display_for_new_views DEFAULT
projection_type FIRST_ANGLE
show_total_unfold_seam YES
tan_edge_display_for_new_views DEFAULT
view_note STD_JIS
view_scale_denominator 3
view_scale_format RATIO_COLON
detail_view_boundary_type CIRCLE
detail_view_scale_factor 2.000000
3.截面和箭头选项
crossec_arrow_length 5.000000
crossec_arrow_style TAIL_ONLINE
crossec_arrow_width 2.000000
crossec_text_place ABOVE_TAIL
crossec_type OLD_STYLE
cutting_line STD_JIS_ALTERNATE
cutting_line_adapt YES
cutting_line_segment 3.000000
def_xhatch_break_around_text NO
def_xhatch_break_margin_size 0.150000
draw_cosms_in_area_xsec NO
remove_cosms_from_xsecs TOTAL
show_quilts_in_total_xsecs NO
4.控制视图中实体的显示
hidden_tangent_edges DEFAULT
hlr_for_pipe_solid_cl NO
hlr_for_threads YES
location_radius DEFAULT(2.)
mesh_surface_lines ON
ref_des_display NO
show_sym_of_suppressed_weld NO
thread_standard STD_ISO_IMP
weld_light_xsec NO
weld_solid_xsec NO
发表于 2006-7-17 18:04:01 | 只看该作者
尺寸控制选项
allow_3d_dimensions YES
angdim_text_orientation PARALLEL_ABOVE
associative_dimensioning YES
blank_zero_tolerance NO
chamfer_45deg_leader_style STD_ISO
clip_diam_dimensions YES
clip_dimensions YES
clip_dim_arrow_style DOUBLE_ARROW
default_dim_elbows YES
dim_fraction_format DEFAULT
dim_leader_length 5.000000
dim_text_gap 0.500000
display_tol_by_1000 NO
draft_scale 1.000000
draw_ang_units ANG_DEG
draw_ang_unit_trail_zeros YES
dual_digits_diff -1
dual_dimensioning NO
dual_dimension_brackets YES
dual_metric_dim_show_fractions NO
dual_secondary_units MM
iso_ordinate_delta YES
lead_trail_zeros STD_METRIC
lead_trail_zeros_scope DIMS
orddim_text_orientation PARALLEL
ord_dim_standard STD_ISO
parallel_dim_placement ABOVE
radial_dimension_display STD_ASME
shrinkage_value_display PERCENT_SHRINK
symmetric_tol_display_standard STD_ISO
text_orientation PARALLEL_DIAM_HORIZ
tol_display YES
tol_text_height_factor 0.750000
tol_text_width_factor 0.750000
use_major_units NO
witness_line_delta 2.500000
witness_line_offset 0.000000
发表于 2006-7-17 18:04:35 | 只看该作者
其它
default_font simfang
dim_dot_box_style DEFAULT
draw_arrow_length 3.000000
draw_arrow_style FILLED
draw_arrow_width 1.000000
draw_sym_height DEFAULT
draw_sym_width DEFAULT
draw_dot_diameter DEFAULT
leader_elbow_length 5.000000
leader_extension_font SOLIDFONT
axis_interior_clipping YES
axis_line_offset 3.000000
circle_axis_offset 3.000000
radial_pattern_axis_circle YES
asme_dtm_on_dia_dim_gtol ON_GTOL
gtol_datums STD_ANSI
gtol_dim_placement ON_BOTTOM
new_iso_set_datums YES
2d_region_columns_fit_text NO
dash_supp_dims_in_region YES
def_bom_balloons_attachment EDGE
def_bom_balloons_snap_lines NO
def_bom_balloons_stagger NO
def_bom_balloons_stagger_value 15.240000
def_bom_balloons_view_offset 20.320000
def_bom_balloons_edge_att_sym ARROWHEAD
def_bom_balloons_surf_att_sym INTEGRAL
min_dist_between_bom_balloons 20.320000
model_digits_in_region NO
reference_bom_balloon_text "DEFAULT"
show_cbl_term_in_region YES
sort_method_in_region DELIMITED
zero_quantity_cell_format EMPTY
draw_layer_overrides_model NO
ignore_model_layer_status YES
model_grid_balloon_display YES
model_grid_balloon_size 4.000000
model_grid_neg_prefix -
model_grid_num_dig_display 0
model_grid_offset DEFAULT
model_grid_text_orientation HORIZONTAL
model_grid_text_position CENTERED
pipe_pt_line_style DEFAULT
pipe_pt_shape CROSS
pipe_pt_size DEFAULT
show_pipe_theor_cl_pts BEND_CL
decimal_marker COMMA_FOR_METRIC_DUAL
default_pipe_bend_note NO
drawing_units MM
harn_tang_line_display NO
line_style_standard STD_ISO
max_balloon_radius 0.000000
min_balloon_radius 0.000000
node_radius DEFAULT
pos_loc_format %s%x%y, %r
sym_flip_rotated_text YES
weld_symbol_standard STD_ISO
yes_no_parameter_display TRUE_FALSE
发表于 2006-7-17 18:13:06 | 只看该作者
wo ding
发表于 2006-7-17 18:32:50 | 只看该作者
谢谢。。。。
发表于 2006-7-17 19:54:56 | 只看该作者
config 表明PTC功能庞大潜力大
用过PTC的人都知道CONFIG文件繁,用好了可以调用很多软件,库等。美国人不得了啊
发表于 2006-7-17 20:07:00 | 只看该作者
太多了,有的都没实际用处
偶只搞有实际用处的
发表于 2006-7-18 12:07:25 | 只看该作者
我狂顶
发表于 2006-7-19 13:27:09 | 只看该作者
谢谢
GMT+8, 2025-2-10 10:05 , Processed in 0.033499 second(s), 14 queries , Gzip On, Redis On.
