查看: 15373|回复: 1
[求助] 结构分析,约束坐标
发表于 2006-8-5 09:43:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
分析时警告
WARNING
The coordinate system used by constraint "SimpleSupport(1)" is different from the
displacement coordinate system defined on one of the underlying nodes.  This may lead to
unexpected results.
SUGGESTION: Define the constraint in the displacement coordinate system of the underlying
mesh.
请教怎样:    Define the constraint in the displacement coordinate system of the underlying
mesh.
发表于 2006-8-5 14:48:33 | 只看该作者
还有
WARNING
There are no MPC's created automatically for coincident-glue mesh mating.  A connection,
spring or rigid link must be created by the user.
怎么创建“MPC's”?
GMT+8, 2025-4-28 22:51 , Processed in 0.020959 second(s), 12 queries , Gzip On, Redis On.
