查看: 15603|回复: 2
如何打印选顶的模块.
发表于 2003-3-16 19:26:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
       进入时选择了模块,开始作图时,预览中见不到,然后,打印时用什么命令.
       指教.
发表于 2003-3-17 16:46:23 | 只看该作者
If you menns "open DWT file" ?
        <Zoom Extend > or <Zoom All> first
   While the template open
发表于 2003-3-18 13:30:34 | 只看该作者
Here in Taiwan "Block" general called as Tu Kuai
                      "template" called as Yang Pang
If you mens : although"Block"is inserted already, But didn't appear ?
I guess this block is a Drawing frame.and the block size is too big compare
with the current drawing objects.
I suggest :
      When you insert the Block(frame), Zoom All or Zoom Extend first.
      If the size isn't proper, delete it and reinsert with different X or Y
      direction again
GMT+8, 2025-4-20 15:00 , Processed in 0.020561 second(s), 13 queries , Gzip On, Redis On.
