查看: 17362|回复: 2
[求助] 恳求各位大哥帮帮忙解决
发表于 2006-9-2 00:25:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
启动LICENSE FILE时,出现下列信息是什么意思
Failed to open the TCP port number in the license
下边是我的license.log的内容:
0:17:17 (lmgrd) -----------------------------------------------
0:17:17 (lmgrd)   Please Note:
0:17:17 (lmgrd)
0:17:17 (lmgrd)   This log is intended for debug purposes only.
0:17:17 (lmgrd)   There are many details in licensing policies
0:17:17 (lmgrd)   that are not reported in the information logged
0:17:17 (lmgrd)   here, so if you use this log file for any kind
0:17:17 (lmgrd)   of usage reporting you will generally produce
0:17:17 (lmgrd)   incorrect results.
0:17:17 (lmgrd)
0:17:17 (lmgrd)
0:17:17 (lmgrd)
0:17:17 (lmgrd) Failed to open the TCP port number in the license.
恳求各位大哥帮帮忙解决。我的机子上装了pro/e 野火2和matlab7.1
发表于 2007-11-2 08:49:08 | 只看该作者
帮帮我吧!谢谢各位了!
发表于 2007-11-2 19:12:10 | 只看该作者
两个软件LICENSE冲突?
得请高人指点了。
GMT+8, 2025-2-20 20:27 , Processed in 0.026707 second(s), 13 queries , Gzip On, Redis On.
