查看: 17056|回复: 0
急问,如何不用在特征列表树上选取方式就能够获得装配组件的procompath
发表于 2006-9-9 07:11:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在获取装配信息时,ProCompath是一个很重要的概念,通过它我们可以获得装配体所有的信息。如下的代码就是用来通过ProSelection获取ProCompath的代码。但是这种方式必须通过在特征列表树上点取特征才能够获取ProSelection,从而获取ProCompath. 请问,有没有办法不通过这种点取方式获得ProCompath,而是通过自动访问特征列表方式获取ProCompath呢?急问,谢谢!
Function : UserAsmcompTransfGet()
Purpose  : Find the transformation matrix of the specified component
int UserAsmcompTransfGet()
        ProError status;
        ProMdl model;
        int nb_sel, i;
        ProMatrix matrix;
        ProAsmcomppath comp_path;
        //ProIdTable comp_id_table;
        ProSelection *sel_list;
        //ProModelitem sel_obj;
        //ProFeature feature;
        //ProFeattype ftype;
        FILE *fp_out=NULL;
        ProName w_name;//, wfile_name;
        ProCharName name;
        status = ProSelect ("prt_or_asm",1,NULL,NULL,NULL,NULL,
                &sel_list,&nb_sel);
        if (status == PRO_TK_NO_ERROR)
                if (nb_sel > 0)
                        status = ProSelectionAsmcomppathGet(sel_list[0],
                                &comp_path);
                        status = ProAsmcomppathTrfGet (&comp_path,PRO_B_TRUE,matrix);
                        status = ProAsmcomppathMdlGet(&comp_path,&model);
                        ProMdlNameGet(model,w_name);
                        ProWstringToString(name,w_name);
                        fp_out = fopen("rptfile.txt", "w");
                        fprintf(fp_out, " ------ Component Location ------ \n\n");
                        fprintf(fp_out, "Component name : %s\n\n",name);
                        fprintf(fp_out, "Matrix :\n\n");
                        for (i=0 ; i<4 ; i++)
                                fprintf(fp_out, "%f\t%f\t%f\t%f\n",
                                matrix[0],matrix[1],
                                matrix[2],matrix[3]);
                        fclose(fp_out);
                        ProStringToWstring(w_name,"rptfile.txt");
                        status = ProInfoWindowDisplay (w_name,NULL,NULL);
                        if (status != PRO_TK_NO_ERROR)
                                return (-1);
        return (PRO_TK_NO_ERROR);
GMT+8, 2025-4-6 13:47 , Processed in 0.065247 second(s), 12 queries , Gzip On, Redis On.
