查看: 18142|回复: 8
caxa xp 数据接口
发表于 2003-3-19 11:22:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为什么在caxa xp     数据接口打开autop的dat文件   打开出来是乱的
在v2就可以打开
发表于 2003-3-20 09:22:13 | 只看该作者
在CAXA电子图板XP中肯定是不能读的。AUTOP的DAT文件是一个线切割的图形文件,建议使用CAXA线切割V2来读取,应该没有什么问题。试试。
发表于 2003-3-26 22:08:26 | 只看该作者
版主你好,我很早就接触CAXA了,现在倒几乎不用了。我一直觉得CAXA的接口不太好,比如IGES,DXF,DAT。输入后常丢图素。前两个我没深究,而DAT我还有较深的体会。我在CIMATRON中做了一个线切割的接口,能输出DAT文件,该类型的文件能正确输入AUTOP中,而CAXA就输不进。我的DAT文件是紧凑型的,同正常的格式稍有区别,但符合AUTOP的规格,我感到CAXA的DAT接口的容错度不高。
版主你可否向软件制造商反映一下。先谢了,我其实一直就关注着CAXA。
下面为我在CIMATRON中输出的DAT文件的例子
A0=-6.49741,-23.89366,-211.16554,1.79668,-205.66725,29.77583,S
A1=-144.39706,12.65295,-205.66725,29.77583,-172.62186,69.66689,S
A2=-144.14041,12.04994,-172.62186,69.66689,-152.71330,75.74775,S
A3=-127.79022,-90.92805,-152.71330,75.74775,-90.39494,73.39959,S
A4=-115.08913,-38.33608,-90.39494,73.39959,-82.88834,71.47181,S
A5=-102.75497,6.29514,-82.88834,71.47181,-61.18698,60.28387,S
A6=-19.89072,117.33029,-61.18698,60.28387,-18.79843,46.91380,N
L0=-18.79843,46.91380,1.87312,46.81886
L1=1.87312,46.81886,1.87312,7.82592
L2=1.87312,7.82592,-0.85041,7.81478
A7=0.14858,82.84793,-0.85041,7.81478,-58.32152,35.81370,S
L3=-58.32152,35.81370,-64.11377,42.84273
A8=-119.25009,-2.65470,-64.11377,42.84273,-70.34216,49.48017,N
A9=-98.44989,19.32062,-70.34216,49.48017,-85.21938,58.36670,N
A10=-109.05733,-11.70542,-85.21938,58.36670,-93.30361,60.61450,N
A11=-127.71001,-90.54980,-93.30361,60.61450,-149.04625,63.00544,N
A12=-141.20325,11.82310,-149.04625,63.00544,-159.43178,60.28819,N
A13=-140.21490,10.49974,-159.43178,60.28819,-165.70613,57.38657,N
A14=-141.23508,12.90298,-165.70613,57.38657,-191.78096,17.67126,N
A15=-139.08124,12.90800,-191.78096,17.67126,-191.99533,13.12730,N
A16=-198.55023,10.87773,-191.99533,13.12730,-200.21927,17.60392,N
A17=-112.63633,-10.88883,-200.21927,17.60392,-203.18492,5.95043,N
A18=-117.84184,-167.76326,-203.18492,5.95043,-211.16554,1.79667,N
C0=-198.55072,10.87721,1.40485
发表于 2003-3-26 22:13:10 | 只看该作者
附图为上例DAT文件所表示的图形。
发表于 2003-3-28 19:56:14 | 只看该作者
刚看到。
稍等,我找人来回答。
发表于 2003-3-28 20:24:45 | 只看该作者
引用————“这个问题如果连 大光头 都解答不了;我肯定是无能为力了。
我们说的CAXA其实指的是CAXA实体设计,至于线切割V2,我们研究的比较少。
我看不懂那些dat的数据,但是我也用过 线切割 做零件;我当时用的是G代码(当然我也没有看懂罗)。
具体做法是先画图(一笔的图),然后生成轨迹(加偏补),选取传丝点,生成G代码,然后传到机床上就可以直接加工了,全过程很简单,好像不用动脑子。如果你要切的文件是dat的,可以先转换成exb,至于怎么转我也不太清楚,你可以问一问 大光头。其实直接用CAXA画图就可以了,绝对比AutoCAD强。
现声明一点,CAXA线切割V2做的不是很好,如果要切上下异型的话需要足够多的内存。而且效果也不是很好,当然这与机床的型号也有关啦。
好像我接触的CAXA都是用G代码实现与机床连接的,真的对dat不是很熟。“
发表于 2003-3-28 21:19:57 | 只看该作者
太谢谢楼上两位大侠了,CAXA有你们两位支撑是大幸!
我也要重新用CAXA了,我的CAXA功力不差哦!(我的吹牛功力更好!!)
adoby兄,我以前对不住你的地方请多包涵!
发表于 2003-3-29 08:44:23 | 只看该作者
我不是大虾,我只是小贼而已
(因为我一直在偷大光头他们家橡皮筋,打他们家玻璃*^_^*)
但是盗亦有道,我想帮大光头打打气,出出气!!
发表于 2003-3-29 09:56:41 | 只看该作者
更正一下;“切上下异型的话需要足够多的内存”这句话应该这样理解:
仅仅针对 线切割 机床;
因为现在画图的机子普遍是 奔II 奔III了,绝对没有问题,但是内存最好上64M;
但是现在旧加工机床的内核普遍停留在486、586水平,最好也要加到64M *^_^*
GMT+8, 2025-4-6 23:27 , Processed in 0.025922 second(s), 12 queries , Gzip On, Redis On.
