查看: 16484|回复: 6
【资料】UG18新功能介绍(Smart Collectors )
发表于 2002-4-6 19:51:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Smart Collectors provide the user a way to select a collection of faces or edges. This new operator will remember the rules defined during the selection. For example, if you add tangent edges, this rule will be remembered. As the model is changed and a new edge is added, the edge will be automatically added to the selection.
This operation is available with taper in V18 and
  will eventually be availble to all features that input faces or edges
发表于 2002-4-6 19:55:22 | 只看该作者
初始特征
发表于 2002-4-6 19:57:57 | 只看该作者
调整特征顺序:
结果
须重新做TAPER
发表于 2002-4-6 20:02:11 | 只看该作者
此类问题,UG18有解决办法:SMART COLLECTOR
做TAPER时面选:MORE,调出FACE COLLECTOR
发表于 2002-4-6 20:05:32 | 只看该作者
用TANGENT FACE项,
选SEED任一侧面,
BOUNDARY:上、下面;
发表于 2002-4-6 20:08:45 | 只看该作者
做了三条侧边BLEND,一条CHAMFER
发表于 2002-4-6 20:10:55 | 只看该作者
调整特征顺序,OK
GMT+8, 2025-4-10 09:43 , Processed in 0.034613 second(s), 12 queries , Gzip On, Redis On.
