查看: 15860|回复: 1
VB.NET与UG 二次开发问题4
头像被屏蔽
发表于 2006-9-27 18:43:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-9-30 22:06:55 | 只看该作者
- In a working directory, copy the files for the FeatureBrowser example.
- Open up the VB .NET project (FeatureBrowser.vbproj) in Visual Studio .Net 2003.
- Add references to NXOpen.dll, NXOpenUI.dll, NXOpen.Utilities.dll.
  To do this, click MB3 on "References" under the FeatureBrowser project in Solution
  Explorer.  Pick "Add Reference..." and then navigate to the location of the dlls.
  These NX dlls can be found in the managed subdirectory under %UGII_ROOT_DIR%.
  Find and highlight the library, click Select and then OK on the Add Reference form.
- Select the Build->Build Solution menu command.
- The executable will be placed in a subdirectory named "bin" under the working
  directory after the build completes.
How to run the example
- Start up an NX3 session and open some parts.
- Go to File - Execute - NX Open.  This will bring up the Execute User Function
  dialog. Browse to the FeatureBrowser.exe location in the "bin" directory.
- Select the FeatureBrowser.exe executable and click OK.  NOTE: you may have to
  change the file type filter to *.exe to allow you to select the .exe file.
GMT+8, 2025-10-19 23:40 , Processed in 0.070532 second(s), 11 queries , Gzip On, Redis On.
