查看: 16717|回复: 1
[求助] 请高手帮忙看一下这个是什么原因,怎么解决。thks.
发表于 2006-10-26 14:39:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
当设置system options---hole Wizard/Toolbox的路径时,提示:
“Unable to open master database due to the following database access error:
The Microsoft Jet database engine cannot open the file'
D:\Program files\Common Files\SOLIDWORKS Data\lang\english\SWBrower.mdb'.
It is already opened exclusively by another user, or you need permission to view its data.”
这个是什么原因呢?安装的不对还是文件坏了?请高手帮忙指点,多谢。
发表于 2006-10-26 16:08:01 | 只看该作者
很显然,安装不完整,卸载干净,重新安装好了。
GMT+8, 2025-4-25 07:44 , Processed in 0.022362 second(s), 11 queries , Gzip On, Redis On.
