查看: 15996|回复: 0
【讨论】Contact in ANSYS 7.0
发表于 2003-3-26 12:23:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Who has extensively used surface-to-surface contacts in ANSYS 7.0? Please give your opinions about it. It will be better if you can compare it with the contact solution in ABAQUS.
Thanks.
GMT+8, 2025-2-2 17:53 , Processed in 0.024169 second(s), 13 queries , Gzip On, Redis On.
