查看: 21901|回复: 11
[资料] 有关显示的问题如何解决? 进来瞧, 全英文.
发表于 2006-11-11 22:18:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Overview
This document lists common display problems and suggested solutions.
The terms used are described, as follows:
•        Refresh Rate: This is the rate of frame draw of a certain model on a certain hardware system. The refresh rate is expressed in FPS (Frames Per Second).
•        Response Time: The selector response time to mouse movements, resulting in highlighting entities.
If display problems are encountered, try to solve them using our suggested solutions in the sections below. Check each section in the order it is presented, ie:
1.        Driver Integration Problems  驱动的问题
2.        Cimatron Graphic Card Settings   Cimatron 显卡设定
3.        Graphic Card Driver Settings (Hardware)   显卡驱动设定(硬件)
4.        Windows Settings Windows设定
If the problem is not solved in one section, try to find a solution in the next section.
Problem:        Picture looks dirty.   画面看起来很脏(乱)
Solution:        Check the Installation-Guide or Vendor-Web-Site to ensure that the driver you are using matches the Cimatron-recommended driver. If not, uninstall the old drivers and install the new driver, as follows:  先看安装指南或网站,确定你的驱动和Cimatron兼容, 如果不是,卸掉旧的安装新的。
1.        Backup the old driver. (You may need to reinstall it for regression cases.)  备份旧驱动
2.        Download the Cimatron-recommended version of the graphic card driver from the relevant website. (ATI, NVIDIA, 3Dlabs etc.)  下载Cimatron推荐的版本。
3.        Uninstall all previous drivers, as follows:  用下面的步骤卸载旧的
Start / Settings / Control Panel / Add or Remove Programs   添加/删除程序
4.        Disable two antivirus services, as follows:  关掉两个病毒防火墙
Start / Settings / Control Panel / Administrative Tools / Services
a.        DefWatch
  or
Symantec DefWatch
b.        Norton AntiVirus Client
     or
Symantec AntiVirus Client
5.        Install the new driver.  安装新的。
注:不管哪两个,只要是防病毒的都关好了。支持的显卡和驱动见第三楼。
Cimatron 显卡设定
Problem:        Dirty view with highlighted traces. 高亮时很乱
Solution:        Select Don’t from the Ignore OpenGL picture copy drop-down list, under Tools / Preferences / General / Display.
看图
Limitation:        Selecting Don’t may result in a degraded pick Response Time (not dramatically).
不知道咋翻。
Remark:        If the problem is not solved, retrieve the default value (Do instead of Don’t).
如果解决不了,请用默认值(用Do换成Don't)
Problem:        Points and sketcher lines disappear.
故障表现: 点或草绘线消失。
Solution:        Uncheck the Skip OpenGL flush checkbox under Tools / Preferences / General / Display.
上一图中需要改的那项下面有个勾选项,取消他(注意不是要你改红框中的,如果你以为这一个问题我也告诉你把DO改成DON‘T我要骂你SB)
Limitation:        Unchecking the option may result in a degraded refresh rate (not dramatically).
限制:会降低刷新率。
Remark:        If the problem is not solved, retrieve the default value (re-check the option).
解决不了就改回去。
Problem:        Unstable card behavior.
故障: 不稳定乱跑。
Solution:        Select Don’t from the Use OpenGL display lists drop-down list, under Tools / Preferences / General / Display.
同上上条解决方案。
Details:        Use OpenGL display lists is a technique of preprocessing display commands into a list, which are drawn faster on a call.
明细, 了解那么清楚干嘛?不翻译了。:
Limitation:        Selecting Don’t may result in a degraded refresh rate.
限制:同上
解决不了改回去。
硬件驱动上的设定
Problem:        Some graphic cards crash and work very slow or leave dirt on the screen.
有的显卡崩溃或者非常慢,又或者在屏幕上留下一些垃圾。
Solution:        Three hardware dependent options exist, as follows:
•        Select Display Properties / Settings / Advanced / OpenGL Settings / Graphic-Card Tab. Set the buffer-flipping (swap) mode to block transfer (Force Swap Copy).
进入显卡的opengl设定(如果不知道,等别人来告诉你),找上面的那什么什么,我电脑上只有中文的,对不上号,大家自已找吧
•        Select Display Properties / Advanced / Troubleshoot  and enable Write Combining.
疑难解答中选启用写入合并。
•        Select Display Properties / Advanced / Card Name and then select Performance & Quality Settings / OpenGL Settings / Custom OpenGL Application Settings / AutoCAD.
自定义的OPENGL设定选用AUTOCAD,专业卡才有的哦!
Remark:        If the problem is not solved for each of the above options, retrieve the default values.
Windows Settings
Windows 设定Problem:        Refresh rate is bad.
Solution:        Select My computer / Properties / Advanced / Performance Settings, and
        then uncheck the Show window contents while dragging checkbox.
不要勾选红框中的选项。
Limitation:        Valid only for XP operating systems. The dragged window will be drawn as a wire rectangle.
XP下才有用。
Problem:        Leftovers on the screen.
故障:屏幕上有残留。
Solution:        Select My computer / Properties / Advanced / Performance Settings, and then uncheck the Fade out menu items after clicking checkbox.
上图中”单击后淡出菜单“取消掉,偶不抓图了。
以下全部略过,懒得讲了。有能力的自个儿瞧吧,无关紧要。
Cimatron Performance Improvement Settings
性能提升设定
Effect:        Refresh rate improvement.
Access:        Menu / View / Settings / Display Quality.
Details:        Use the slider to reduce the display quality, as required.
Limitation:        The display will appear as less smooth.
Access:        Menu / View / Settings / Fast Refresh Auto Hide.
Details:        Check to enable and move the slider to a higher refresh rate.
Limitation:         In dynamic ZPR, some figures and small triangles will disappear.
Effect:                Document load time improvement.
Access:        Menu / Tools / Preferences / General / Display /
Save & Load display mesh
Details:        Check to save the mesh instead of re-faceting on each load.
Limitation:        Increases the disk space usage.
Rare Problems
Access:        Display Properties / Settings / Screen Resolution.
Details:        Setting a lower resolution may improve the refresh rate.
Limitation:        Rough picture.
Access:        Display Properties / Settings / Colors.
Details:        The true color may be slower than the Highest Color.
Limitation:        Unnoticed.
Access:        Display Properties / Troubleshoot / Hardware Acceleration.
Details:        Move the slider all the way to the end, to obtain the maximum refresh rate.
Limitation:        Some cards may cause stability and/or picture quality problems.
参与人数 1技术 +1 收起 理由
ganxuesong + 1 见解非常独到
发表于 2006-11-11 22:23:31 | 只看该作者
所因何事?
发表于 2006-11-11 22:30:29 | 只看该作者
因为今天光棍节,我却要守身如玉。
发表于 2006-11-12 19:07:12 | 只看该作者
看不懂郁闷
发表于 2006-11-12 19:34:02 | 只看该作者
好贴  加分  除了上面贴图的地方是关键外  显卡芯片所对应的驱动程序版本一定要对应 不然显示性能很差  我用的NVIDIA的专业卡  对应的最佳驱动版本是77.56 其他芯片的兄弟请到NVIDIA,ATI的官方网站下载对应的最合适驱动版本!~
发表于 2006-11-12 19:43:43 | 只看该作者
都一把年纪了,还要来答谢,郁闷。
多谢版主加分....
发表于 2006-11-26 22:45:09 | 只看该作者
学习中,
发表于 2006-11-26 23:17:34 | 只看该作者
小顶一下收工睡觉!
同志们辛苦了
发表于 2006-11-27 08:02:41 | 只看该作者
多谢多谢~~~前辈们的指点真是让人受益啊~~
发表于 2006-11-27 10:33:51 | 只看该作者
多谢楼主.师着,传道授业解惑也.楼主当之无愧
GMT+8, 2025-4-25 10:10 , Processed in 0.027200 second(s), 12 queries , Gzip On, Redis On.
