查看: 17342|回复: 11
关于炸开的问题
发表于 2003-3-27 18:09:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是用的2000版的CAD 我在标注的时候,有时候把标注炸开,但不知道用什么命令把它恢复!!!炸开后原来的圆周符号也变成方框了!!
头像被屏蔽
发表于 2003-3-27 18:50:14 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2003-3-28 10:43:51 | 只看该作者
可以单独改吗
发表于 2003-3-28 11:18:22 | 只看该作者
像这样行不行呀?
发表于 2003-3-28 13:37:59 | 只看该作者
1." %%C" expression is only suit for .shx font, After Exploded all objects
     become "line" type.
     AutoCAD system never recognize this  linetype (%%C). This,s the
     reason why it shown as "vacancy".
2. Comm.DIMEDIT [$raquo][$raquo] n    can solve this problem.
很热心的GG,,加分鼓励::b
发表于 2003-3-28 16:26:35 | 只看该作者
楼上的哥门,以后麻烦你有中文可以吗!!小弟我文化有限!!
发表于 2003-3-28 16:31:15 | 只看该作者
I speak and write Chinese. But I live in Taiwan, and Traditional Chinese
is my only choice.
I am awfully sorry to let you know I CAN'T KEY IN GB CODE.
If this page can translate Tradiional Chinese to Simplify Chinese, I sure
glad to write in Chinese at once. Here in Taiwan the page I read is translated to Traditional Chinese immediately.
I try to send programs(Autolisp) and paste graphs,but still not success,
I don't know why ? may be I can sed it to THe "page manager" bg
E-mail and ask him to paste for me.
发表于 2003-3-28 16:39:22 | 只看该作者
哦,原来如此不好意思!!
发表于 2003-3-29 10:21:35 | 只看该作者
The operate procedure of DDEDIT and DIMEDIT is almost the same.
except on sequence.
       DDEDIT [$raquo][$raquo] select object [$raquo][$raquo] key in correct text [$raquo][$raquo] OK
       DIMEDIT [$raquo][$raquo] key in correct text [$raquo][$raquo] select object [$raquo][$raquo] OK
So, DIMEDIT is more suit for your situation.
I wonder what font style did you set ? because when I set the style as
TXT.shx, the "[$Oslash]" symbol still the same after explode.
发表于 2003-3-29 12:56:04 | 只看该作者
  I don't know why ? 。。。。
你可以直接用繁体中文,可以显示的。关于如何贴图请看这里。https://www.icax.org/viewthread. ... %3D1&page=#pid=
2、加贴或者回复的时候使用高级编辑器可以贴图(要使用“增加回复”),附件贴图请使用JPG或者GIF,可以直接显示。其他文件格式请使用ACDSEE等软件转换!
图片的大小一般宽度不得大于600,可以试用ACDSEE调整。
GMT+8, 2025-4-20 23:05 , Processed in 0.024662 second(s), 13 queries , Gzip On, Redis On.
