查看: 16293|回复: 2
[求助] 新人刚接触E7有几个问题请斑竹和各位朋友帮忙看看
发表于 2006-11-14 19:55:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好最近才刚刚用E7.1学习加工编程有好多不明白的地方请大家帮忙
1,给我们单位编程的人是用的E7.0他送来的程序里带的其中一张图里是一把棒糖刀的加工图但是我想知道他
是怎么在上面标住的刀直径和刀杆直径的?
2,我试者用他那样的棒糖刀计算加工时~~就会提示我切削是刀具路径不会计算槽铣刀/立铣刀
问了些自己决的很是问题的问题,各位千万别笑我`一定要帮帮我
由于刚刚接触Cimatron 有好多地方不懂,以后还请不吝指教
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2006-11-14 20:01:10 | 只看该作者
先谢谢大家~~有的地方可能说道不明白~还请大家指出
另外我想知道  IT 的后置里是怎么生成的这样的  加工单的
            drawing_number : ***
No.1     NC file name : ******.E10-1.FAN-38
comment  : No Text
Operator :
    proc_No. 1                         proc_type = WCUT
    surf_tol.     = 0.03               stock     = 0.3
    z_up          = 0.0                down_step = 0.35
    z_down        = -50.0
    (xm ,ym ,zm)  = ( -31.0       ,-29.0         ,-49.7    )
    (xM ,yM ,zM)  = ( 31.0        ,41.0          ,30.0     )
    rapid_feed    = 148.095       mm | 0.03      min
    general_feed  = 132451.385    mm | 360.326   min
    Tool_name     = E10                comment: NO TEXT
    tool_type     = D10.0_R0.0         tool_length = 52.0
    spindle_speed = 1000 rpm           feed        = 350 mm / min.
    holder :
    rapid_feed    = 148.095       mm | 0.03      min.
    general_feed  = 132451.385    mm | 360.326   min.
No.2     NC file name : *****.E10-2.FAN-38
comment  : No Text
Operator :
    surf_tol.     = 0.005              stock     = 0.0
    z_down        = -11.5
    (xm ,ym ,zm)  = ( -18.303     ,-16.12        ,-11.5    )
    (xM ,yM ,zM)  = ( 28.571      ,15.891        ,30.0     )
    rapid_feed    = 80.485        mm | 0.016     min
    general_feed  = 4280.214      mm | 12.326    min
    proc_No. 2                         proc_type = WCUT
    z_up          = -11.995            down_step = 0.0
    z_down        = -11.995
    (xm ,ym ,zm)  = ( -14.6       ,-12.5         ,-11.995  )
    (xM ,yM ,zM)  = ( 24.9        ,24.2          ,30.0     )
    rapid_feed    = 108.74        mm | 0.022     min
    general_feed  = 311.415       mm | 0.91      min
    proc_No. 3                         proc_type = WCUT
    z_up          = -12.0              down_step = 0.3
    z_down        = -49.6
    (xm ,ym ,zm)  = ( -18.513     ,-16.347       ,-49.6    )
    (xM ,yM ,zM)  = ( 28.845      ,16.131        ,30.0     )
    rapid_feed    = 129.257       mm | 0.026     min
    general_feed  = 16211.283     mm | 46.589    min
    proc_No. 4                         proc_type = WCUT
    z_up          = -50.0              down_step = 0.0
    z_down        = -50.0
    (xm ,ym ,zm)  = ( -29.999     ,-28.001       ,-50.0    )
    (xM ,yM ,zM)  = ( 29.999      ,40.001        ,30.0     )
    rapid_feed    = 218.364       mm | 0.044     min
    general_feed  = 663.74        mm | 1.916     min
    holder :
    rapid_feed    = 536.847       mm | 0.107     min.
    general_feed  = 21466.652     mm | 61.741    min.
(Xm ,Ym ,Zm)  = ( -31.0           ,-29.0         ,-50.0    )
(XM ,YM ,ZM)  = ( 31.0            ,41.0          ,30.0     )
Rapid_Feed    = 684.942           mm | 0.137      min.
General_Feed  = 153918.038        mm | 422.066    min.
------------------------- THE END  -------------------------------
发表于 2006-11-15 10:31:07 | 只看该作者
原帖由 死亡v骑士 于 2006-11-14 20:01 发表
            drawing_num ...
期待!
GMT+8, 2025-4-27 18:35 , Processed in 0.023691 second(s), 12 queries , Gzip On, Redis On.
