查看: 15622|回复: 1
【求助】
发表于 2003-4-2 15:31:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
::?::?请各路高手帮帮忙!!!小弟在工作中,打印PART的着色文件时,原来在图中用同一方法同样字体创建的注释,居然有的能打出来,有些却只有线条,剩下的干脆什么都没有,很让我困惑!
发表于 2003-4-2 16:22:09 | 只看该作者
我将工程图的配置文件(dtl文件)中笔的编号与其相对应的对象列出,希望对你有所帮助。
! Pen 1 = white entities (object lines,text)
! Pen 2 = yellow entities (dimensions, cross hatching)
! Pen 3 = gray entities (hidden lines)
! Pen 4 = red entities (can use for drawing border if you change the
! entity color to red in the format file)
! Pen 5 = green entities (sheetmetal)
! Pen 6 = cyan entities (section)
! Pen 7 = dark gray entities (dimmed)
! Pen 8 = blue entities (spline surface grid
GMT+8, 2025-4-12 11:15 , Processed in 0.042532 second(s), 12 queries , Gzip On, Redis On.
