查看: 15816|回复: 3
[求助] nx4.0 tool bar(icon) problem
发表于 2006-12-31 16:54:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear all xperts
there's a little problem on my nx4.0
the menu bar icon are very very big
even i change it to extra small it still big
i wondering is that my version of nx gone bad
or just the setting issue.
thank you all
发表于 2007-1-1 11:21:17 | 只看该作者
在自定义里面可以修改的
只要把下面的文字去掉就可以了
发表于 2007-1-1 11:21:50 | 只看该作者
你搜一下以前的帖子吧
我现在没有UG
也说不清楚
发表于 2007-1-2 20:00:58 | 只看该作者
i find it
thank you
GMT+8, 2025-4-30 05:37 , Processed in 0.020851 second(s), 11 queries , Gzip On, Redis On.
