查看: 15963|回复: 3
[求助] 大家帮忙看看这个Fill过程的问题
发表于 2007-1-17 09:15:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位帮忙看看这个是什么问题,fill时在0.78s时有问题
analysis is beginning ....
  Filling phase:    Status: V  = Velocity control
                            P  = Pressure control
                            V/P= Velocity/pressure switch-over
|  Time  | Volume|  Pressure   | Clamp force|Flow rate|Status |
|  (s)   |  (%)  |    (MPa)    |  (tonne)   |(cm^3/s) |       |
|   0.13 |  3.96 |        8.80 |       0.13 |   30.89 |   V   |
|   0.26 |  8.71 |       11.71 |       0.51 |   31.76 |   V   |
|   0.39 | 13.57 |       13.93 |       1.04 |   32.21 |   V   |
|   0.52 | 18.34 |       15.63 |       1.61 |   32.38 |   V   |
|   0.65 | 23.22 |       17.19 |       2.29 |   32.46 |   V   |
|   0.78 |30182.90 |        0.00 |       0.00 |28114000.32 |   V   |
69.8553
|   0.91 | 32.84 |       20.10 |       4.01 |   32.54 |   V   |
|   1.04 | 37.72 |       21.58 |       5.10 |   32.62 |   V   |
|   1.17 | 42.49 |       23.11 |       6.43 |   32.57 |   V   |
|   1.30 | 47.34 |       24.75 |       7.97 |   32.67 |   V   |
|   1.44 | 52.35 |       26.48 |       9.79 |   32.67 |   V   |
网格情况
Entity counts--------------------------------
    Surface triangles                 28672
    Nodes                         14330
    Beams                         0
    Connectivity regions         1
    Mesh volume                         83.783 cm^3
    Mesh area                         763.218 cm^2
Edge details---------------------------------
    Free edges                         0
    Manifold edges                 43008
    Non-manifold edges                 0
Orientation details--------------------------
    Elements not oriented         0
Intersection details-------------------------
    Element intersections         0
    Fully overlapping elements         0
    Duplicate beams                  0
Surface triangle aspect ratio----------------
    Minimum aspect ratio         1.155034
    Maximum aspect ratio         7.023306
    Average aspect ratio         1.939249
Match ratio----------------------------------
    Match ratio                         93.0%
    Reciprocal ratio                 87.2%
发表于 2007-1-17 20:16:29 | 只看该作者
软件bug
发表于 2007-1-18 22:31:24 | 只看该作者
看看0.78s填充到那里?检查一下那里的模型试试。。。
发表于 2007-2-5 17:02:48 | 只看该作者
重新啟動看看
GMT+8, 2025-2-23 02:21 , Processed in 0.021551 second(s), 10 queries , Gzip On, Redis On.
