查看: 17739|回复: 4
请教一个COSMOSWORKS问题
发表于 2002-1-26 20:58:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    我向大家请教一个COSMOSWORKS的问题,如何在一个很不规则的曲面上施加压力随着位置变化的负载条件?
    其它的,如DESIGNSPACE或VISUAL NASTRAN(都没有用过)可以加这样的负载吗?
    谢谢!
发表于 2002-1-27 09:00:25 | 只看该作者
you can't make it in cosmos/works. but you can do it in Cosmos/M, Ansys etc. FEA softwares. However, you have to apply pressure on elements.
发表于 2002-1-27 10:56:28 | 只看该作者
  Thank you for your anwser.once I tried to realize this problem in ANSYS5.5. But it is not easy.especially, how to capture and re-orient face element which is within the volume element. Can you give me further informative tutor in ANSYS or Cosmos/M.
发表于 2002-1-30 11:33:00 | 只看该作者
zyd-ysf wrote:
   Thank you for your anwser.once I tried to realize this problem in ANSYS5.5. But it is not easy.especially, how to capture and re-orient face element which is within the volume element. Can you give me further informative tutor in ANSYS or Cosmos/M. [/quote]
高手在哪里?谢谢!
发表于 2002-1-30 12:34:30 | 只看该作者
呵呵!COSMOS没用过,在I-DEAS中可以用数据面,加变载荷!
GMT+8, 2025-4-11 00:31 , Processed in 0.025904 second(s), 13 queries , Gzip On, Redis On.
