查看: 16261|回复: 1
【求助】收缩率的问题?
发表于 2003-4-7 09:59:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  模具设计时有一个收缩率,所以比实际塑件的尺寸要大。
做MOLDFLOW分析时怎么处理收缩率?因为转IGES,STL时是没有考虑收缩率的。
发表于 2003-4-7 12:46:50 | 只看该作者
you can set the shrink ratio in other cad toll, for example pro/engineer,solidoworks.
but i don't think it is important to set the shrink ratio in moldflow.
if you don't set the shrink ratio,you can also get the accurate result.
GMT+8, 2025-4-20 00:51 , Processed in 0.019401 second(s), 12 queries , Gzip On, Redis On.
