查看: 21593|回复: 18
[资料] 实用快捷键——使操作更顺畅
发表于 2007-3-21 17:39:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Menu > File
Alt+S Save as
Alt+R File
Alt+I Image/Mask layer
Ctrl+7 Pix
Alt+E Exit
Menu > Edit
        Ctrl+Z Undo
Ctrl+X Cut
Ctrl+C Copy
Ctrl+V Paste
Menu > Delete
        Alt+A Delete active
Alt+X Del active image layer
发表于 2007-3-21 17:40:10 | 只看该作者
Menu > Layouts
        F9 User windows
F8 Perspective
F6 Side
F7 Back
F5 Top
Menu > Display Tgls
        F12 Model
Menu > Image
        Shift+Ctrl+X Cut image
Shift+Ctrl+C Copy image
Shift+Ctrl+V Paste image
        Ctrl+4 Tgl paint panel
Ctrl+2 Paint Default UI
Ctrl+3 Modeling Default UI
发表于 2007-3-21 17:40:47 | 只看该作者
Menu > Image > New
        Ctrl+L Image layer
Menu > Image > Modify layer
        Ctrl+M Merge below
Ctrl+K Clear image
Ctrl+I Invert layer mask
Alt+H Tgl selection/mask
Menu > Render
        Ctrl+6 Globals
发表于 2007-3-21 17:41:16 | 只看该作者
Menu > Animation
        Alt+K Set keyframe
Alt+P Playback
Menu > Windows > Multi-lister
        Ctrl+1 List all
Menu > Windows > Information
        Ctrl+5 Information window
发表于 2007-3-21 17:41:42 | 只看该作者
Palette > Pick
        Ctrl+N Nothing
Ctrl+O Object
Ctrl+E Edit point
Palette > Xform
        Alt+M Move
Palette > Cameras
        Alt+L Look at
发表于 2007-3-21 17:42:25 | 只看该作者
Action menu > Pick
        Ctrl+N Nothing
Ctrl+E Keyframes
Ctrl+O Curves
Ctrl+T Template
Action menu > Views
        Alt+L Look at
Action menu > DispTools
        Alt+T Tgl template
发表于 2007-3-21 17:42:50 | 只看该作者
Special > Display Functions
        Alt+O Display all, off
Alt+O Display all, current
Shift+Alt+O Display active, off
Shift+Alt+C Display active, current
Special > Animation Functions
        F11 Show pose frame 2
Alt+F12 Show pose frame 4
发表于 2007-3-21 17:43:30 | 只看该作者
SKETCHING HOTKEYS
Palette > Brushes > Pencil
Palette > Brushes > Marker
Palette > Brushes > Airbrush
Palette > Brushes > Paintbrush
Palette > Brushes > Sharpenbrush
Palette > Brushes > Blurbrush
Palette > Brushes > Smearbrush
Palette > Brushes > Clonebrush
1 Paint mode
2 Erase Mode
3 Hide Mode
4 Show Mode
r Interactive brush radius modification
o Interactive brush opacity modification
t Interactive brush rotation modification
p Interactive brush aspect ratio modification
x Reset brush attributes
Palette > MagicWand Modification
Palette > Marquee (rectangle)
Palette > Marquee (circle)
Palette > Marquee (ellipse)
a Add to Marquee mode and Magic Wand
s Subtract from Marquee mode and Magic Wand
n New marquee and Magic Wand
c Grab color
l Clonebrush re-select source
z Pick image layer by co lour
space Pan image
Ctrl+space Hide floating windows
发表于 2007-3-21 17:46:04 | 只看该作者
希望对大家有帮助
发表于 2007-3-22 11:12:37 | 只看该作者
Ctrl+space :Hide floating windows
改正为Ctrl+Alt+space :Hide floating windows
在默认的布局中shelf和floating windows不能隐藏,在 paint,modeling,visualize中这个快捷键可以起作用
里面不免有错,发现的希望能改正出来
GMT+8, 2025-4-19 22:20 , Processed in 0.024005 second(s), 12 queries , Gzip On, Redis On.
