查看: 16612|回复: 1
求助ug中某些功能,紧急!!!
发表于 2003-4-12 10:06:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助ug中analysis-->Minimum radius和analysis-->face-->radius 的应用有何区别
发表于 2003-4-12 16:23:50 | 只看该作者
看看帮助吧。
这问题是二次开发的问题吗?
analysis-->Minimum Radius
Finds where the radius of curvature is smallest on a face (or a collection of faces) on a solid or sheet body. This option is useful for locating a tiny region with a very small radius of curvature (a "hook" or "reversal" in the surface) that otherwise might go unnoticed. You can use this option to detect glitches in your geometry, or to determine the size of the cutting tool needed for machining the part.
You can use Face Analysis to create displays for a number of analysis types, including shaded, color-coded plots, color-coded spines on face grid points, and face reflections. Face Analysis displays can be useful for detecting inflections, variations, and defects on faces. You can also use Reflection options to create particular environments. This can be useful for visualizing objects and evaluating their aesthetic quality. You can dynamically rotate and zoom the face analysis display. This option allows you to select multiple faces and display temporary color analyses.
To automatically set the Display Mode to Face Analysis in the work view, if it is not already, open the Face Analysis dialog.
GMT+8, 2025-4-20 05:45 , Processed in 0.021451 second(s), 11 queries , Gzip On, Redis On.
