查看: 17273|回复: 10
【分享】在Drawing中和SnapLine来对齐尺寸等
发表于 2002-1-26 23:48:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Drawing Snap Lines
Here is a little tip to speed up drawing cleaning up.  It is a snap line.  A snap line is a line that shows up on the screen but not on the printed drawing.  It allows you to line up balloons, notes, or any draft entities that can be moved using the normal move command.  When an entity is moved near the snap line, it "snaps" to it.  The moved entity will change colors from red to violet when it is attached to the snap line.  Using the snap line, balloons can be lined up in a perfect straight line.  No more eyeballing to try to get them straight.  Figure 1 shows several balloons lined up on two snap lines.
Snap lines can be assigned to a view, a datum plane or any geometry edge and then move with that view.  A snap line can be moved by the normal move command, or it can be moved using Modify > Snap Line.  The great thing is that when the snap line is moved, all the entities aligned to it move with it.
To create a snap line pick Create > Snap Line and follow the prompts.  The units for placement are in millimeters no matter what the drawing units are so you will need to pick an offset value like 10 or 50.  Play around with different attachments.  Now it is easy to align draft entities and have them all move together.
发表于 2006-1-14 23:43:07 | 只看该作者
看不懂...晕
发表于 2006-1-15 08:37:57 | 只看该作者
原帖由 Jester 于 2006-1-14 23:43 发表
看不懂...晕
这么老的贴子都给你找出来了,pf。
早上无事,帮你翻翻,译得不好,有错误的地方请指正:
工程图中的捕捉线
这里给大家一个快速整理工程图的小提示,它就是捕捉线。捕捉线是一条显示在
屏幕上的线但不会打印出来。它用来使球标、注释或其它的草图实体排列在一条
线上,只要移动这些草图实体就行。当一个草图实体移动到捕捉线附近,它将自动
对齐到捕捉线上,并且颜色将从红色变成紫红色。利用捕捉线,球标能够很好的对齐到一条直线上,而不再需要用
肉眼目测的方式。图1中就是几个球标排列在2条捕捉线上。
捕捉线能够被指定给一个视图,基准面和任何边线,并且,捕捉线会跟随视图移动。
捕捉线能用正常的移动命令来移动,或者可以用菜单 Modify-snap line来移动
(译者:在野火2中,你可以直接选中捕捉线,光标变成2个箭头,直接用鼠标按住
来移动,很方便。)。比较好的是,当捕捉线移动了,对齐到它的实体也会跟着移动。
要创建捕捉线,可以用命令Create-Snap line,然后跟着命令提示即可。
(译者:野火2中,insert-snap line)。不管你使用的工程图的单位如何,捕捉线
放置的单位都是毫米,所以你可以输入偏移值如10或50。这样,你就能
很方便的通过移动草图实体来对齐它们了。
[ 本帖最后由 djYang 于 2006-1-15 08:44 编辑 ]
发表于 2006-1-15 08:43:31 | 只看该作者
顺便补几个图,再补充一下:
如下图,用来控制 是否显示 snap line,是否对齐到snap line。
发表于 2006-1-15 08:48:42 | 只看该作者
创建捕捉线
发表于 2006-1-15 08:49:05 | 只看该作者
移动捕捉线
发表于 2006-1-15 09:25:29 | 只看该作者
斑竹,强啊,顺变请教下,如何知道产品最大尺寸(X,Y,Z)的
发表于 2006-1-15 10:03:38 | 只看该作者
原帖由 dss1280 于 2006-1-15 09:25 发表
可以这样去测。有点麻烦
发表于 2006-1-15 10:09:03 | 只看该作者
还可以这样。
发表于 2006-1-15 10:09:47 | 只看该作者
好像也就这个方法比较好用了。
GMT+8, 2025-4-29 20:09 , Processed in 0.025334 second(s), 11 queries , Gzip On, Redis On.
