查看: 17616|回复: 4
请教vb.net下UG二次开发:拉伸特征方位变换(有源码)
发表于 2007-3-27 14:09:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
总是变换不成功,弹出错误对话框,
请高人指点,多谢!!!
' NX 4.0.0.25
' Journal created by nmgf on Tue Mar 27 11:12:31 2007 中国标准时间
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module UGTransformTest
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        '  菜单: 插入->曲线->Basic Curves...
        Dim startPoint1 As Point3d = New Point3d(-30, 30, 0.0)
        Dim endPoint1 As Point3d = New Point3d(60, 30, 0.0)
        Dim line1 As Line
        line1 = workPart.Curves.CreateLine(startPoint1, endPoint1)
        Dim startPoint2 As Point3d = New Point3d(60, 30, 0.0)
        Dim endPoint2 As Point3d = New Point3d(60, -30, 0.0)
        Dim line2 As Line
        line2 = workPart.Curves.CreateLine(startPoint2, endPoint2)
        Dim startPoint3 As Point3d = New Point3d(60, -30, 0.0)
        Dim endPoint3 As Point3d = New Point3d(-30, -30, 0.0)
        Dim line3 As Line
        line3 = workPart.Curves.CreateLine(startPoint3, endPoint3)
        Dim startPoint4 As Point3d = New Point3d(-30, -30, 0.0)
        Dim endPoint4 As Point3d = New Point3d(-30, 30, 0.0)
        Dim line4 As Line
        line4 = workPart.Curves.CreateLine(startPoint4, endPoint4)
        '  菜单: 插入->Design Feature->拉伸...
        Dim section1 As Section
        section1 = workPart.Sections.CreateSection(0.02413, 0.0254, 0.5)
        Dim nullFeatures_Feature As Features.Feature = Nothing
        Dim extrudeBuilder1 As Features.ExtrudeBuilder
        extrudeBuilder1 = workPart.Features.CreateExtrudeBuilder(nullFeatures_Feature)
        extrudeBuilder1.Section = section1
        Dim limits1 As GeometricUtilities.Limits
        limits1 = extrudeBuilder1.Limits
        Dim featureOptions1 As GeometricUtilities.FeatureOptions
        featureOptions1 = extrudeBuilder1.FeatureOptions
        Dim linearLimits1 As GeometricUtilities.LinearLimits = CType(limits1, GeometricUtilities.LinearLimits)
        Dim extend1 As GeometricUtilities.Extend
        extend1 = linearLimits1.StartExtend
        Dim extend2 As GeometricUtilities.Extend
        extend2 = linearLimits1.EndExtend
        Dim booleanOperation1 As GeometricUtilities.BooleanOperation
        booleanOperation1 = extrudeBuilder1.BooleanOperation
        Dim direction1 As Direction
        direction1 = extrudeBuilder1.Direction
        Dim featureOffset1 As GeometricUtilities.FeatureOffset
        featureOffset1 = extrudeBuilder1.Offset
        Dim simpleDraft1 As GeometricUtilities.SimpleDraft
        simpleDraft1 = extrudeBuilder1.Draft
        Dim featureOptions2 As GeometricUtilities.FeatureOptions
        featureOptions2 = extrudeBuilder1.FeatureOptions
        extend1.SetValue("0")
        extend2.SetValue("25")
        featureOffset1.SetStartOffset("0")
        featureOffset1.SetEndOffset("5")
        featureOffset1.OffsetType = GeometricUtilities.Type.NonsymmetricOffset
        simpleDraft1.SetDraftAngle("2")
        simpleDraft1.DraftType = GeometricUtilities.SimpleDraft.SimpleDraftType.SimpleFromStart
        Dim curves1(3) As Curve
        curves1(0) = line3
        curves1(1) = line2
        curves1(2) = line1
        curves1(3) = line4
        Dim curveDumbRule1 As CurveDumbRule
        curveDumbRule1 = workPart.ScRuleFactory.CreateRuleCurveDumb(curves1)
        section1.AllowSelfIntersection(False)
        Dim rules1(0) As SelectionIntentRule
        rules1(0) = curveDumbRule1
        Dim nullNXObject As NXObject = Nothing
        Dim helpPoint1 As Point3d = New Point3d(33.1834217214209, -32.8259757986841, 0.0)
        section1.AddToSection(rules1, line3, nullNXObject, nullNXObject, helpPoint1, Section.Mode.Create)
        Dim origin1 As Point3d = New Point3d(11.40625, -7.96875000000001, 0.0)
        Dim vector1 As Vector3d = New Vector3d(0.0, 0.0, 1.0)
        Dim direction2 As Direction
        direction2 = workPart.Directions.CreateDirection(origin1, vector1, SmartObject.UpdateOption.WithinModeling)
        extrudeBuilder1.Direction = direction2
        Dim feature1 As Features.Feature
        feature1 = extrudeBuilder1.CommitFeature()
        extrudeBuilder1.Destroy()
        '  菜单: 工具->日记->停止
        Dim fs() As Features.Feature = workPart.Features.ToArray
        Dim count As Integer = fs.GetLength(0)
        Dim i As Integer = 0
        Dim featureTag(count - 1) As Tag
        For Each f As Features.Feature In fs
            featureTag(i) = f.Tag
            i += 1
        Next
        Dim transMode As Integer = 2
        Dim csysTrans(1, 11) As Double
        csysTrans(0, 0) = 0
        csysTrans(0, 1) = 0
        csysTrans(0, 2) = 0
        csysTrans(0, 3) = 1
        csysTrans(0, 4) = 0
        csysTrans(0, 5) = 0
        csysTrans(0, 6) = 0
        csysTrans(0, 7) = 1
        csysTrans(0, 8) = 0
        csysTrans(0, 9) = 0
        csysTrans(0, 10) = 0
        csysTrans(0, 11) = 1
        csysTrans(1, 0) = 120
        csysTrans(1, 1) = 0
        csysTrans(1, 2) = 0
        csysTrans(1, 3) = 0
        csysTrans(1, 4) = 0
        csysTrans(1, 5) = 1
        csysTrans(1, 6) = 1
        csysTrans(1, 7) = 0
        csysTrans(1, 8) = 0
        csysTrans(1, 9) = 0
        csysTrans(1, 10) = 1
        csysTrans(1, 11) = 0
        Dim theUFSession As UFSession = UFSession.GetUFSession
        theUFSession.Modl.MoveFeature(featureTag, transMode, csysTrans)
        theUFSession.Modl.Update()
    End Sub
End Module
发表于 2007-3-28 15:15:13 | 只看该作者
re:
(附源码)
我用block特征测试了一下,完全能够变换,没有出现任何错误
所以我认为可能是拉伸特征是从曲线拉伸的原因,因为拉伸体是曲线的子特征,所以应该变换那些曲线特征!
可是,如何得到那些曲线特征呢?我只能用CreateLine得到Line对象,有没有办法得到拉伸体的曲线特征呢 ?
多谢
请高人指点~~~~~~
对了,我用的是UG NX4, VB.NET
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Transform
    Sub Main()
        Dim blockFeatureBuilder1 As Features.BlockFeatureBuilder
        blockFeatureBuilder1 = workPart.Features.CreateBlockFeatureBuilder(nullFeatures_Feature)
        Dim basePoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
        blockFeatureBuilder1.SetOriginAndLengths(basePoint1, "100", "80", "10")
        Dim nullBody As Body = Nothing
        blockFeatureBuilder1.SetBooleanOperationAndTarget(Features.Feature.BooleanType.Create, nullBody)
        feature1 = blockFeatureBuilder1.CommitFeature()
        blockFeatureBuilder1.Destroy()
        Dim theBodies() As Body = workPart.Bodies.ToArray
        Dim theFeatures() As Features.Feature = theBodies(0).GetFeatures
        Dim bodyTag(0) As Tag
        bodyTag(0) = theFeatures(0).Tag
        csysTrans(0, 0) = 0
        csysTrans(0, 1) = 0
        csysTrans(0, 2) = 0
        csysTrans(0, 3) = 1
        csysTrans(0, 4) = 0
        csysTrans(0, 5) = 0
        csysTrans(0, 6) = 0
        csysTrans(0, 7) = 1
        csysTrans(0, 8) = 0
        csysTrans(0, 9) = 0
        csysTrans(1, 1) = 0
        csysTrans(1, 2) = 0
        csysTrans(1, 3) = 0
        csysTrans(1, 4) = 0
        csysTrans(1, 5) = 1
        csysTrans(1, 6) = 1
        csysTrans(1, 7) = 0
        csysTrans(1, 8) = 0
        csysTrans(1, 9) = 0
        theUFSession.Modl.MoveFeature(bodyTag, transMode, csysTrans)
    End Sub
End Module
发表于 2007-3-31 13:07:04 | 只看该作者
提前~~,让高人看到~~
发表于 2007-4-13 10:48:55 | 只看该作者
高手都不来了吗?遗憾~~
发表于 2007-6-20 02:31:43 | 只看该作者
vb也可以做吗
可不可以告诉我要什么插件
GMT+8, 2025-4-7 16:59 , Processed in 0.022232 second(s), 11 queries , Gzip On, Redis On.
