查看: 15692|回复: 1
[原创] 请问这些 是什么意思
发表于 2007-3-30 00:15:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是冷却分析的screem output,但一直不明白是什么意思
还有冷却分析的过程和原理是怎么样的?
哪位大哥解答一下,谢谢了先
|External  |Cycle time|Avg temp  |Avg temp  |Dif temp |Dif temp   |Circ temp |
|iteration  |   (s)         |iteration    |deviation   |iteration |deviation |residual    |
|        1 |   35.000 |       20 |27.137600 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |       13 |15.804500 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |        8 | 4.399410 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |        8 | 2.423190 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |        9 | 0.267805 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |        4 | 0.061883 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |       12 | 0.017038 |        0 | 0.000000 | 1.000000 |
|        1 |   35.000 |        8 | 0.000481 |        0 | 0.000000 | 1.000000 |
|        2 |   35.000 |       25 | 6.313360 |        0 | 0.000000 | 1.000000 |
|        2 |   35.000 |        5 | 0.007072 |        0 | 0.000000 | 1.000000 |
|        2 |   35.000 |        7 | 0.002603 |        0 | 0.000000 | 1.000000 |
发表于 2007-3-31 00:45:34 | 只看该作者
GMT+8, 2025-4-29 05:35 , Processed in 0.020665 second(s), 11 queries , Gzip On, Redis On.
