查看: 16684|回复: 3
[讨论] packing phase 的百分比表示什么意思?
发表于 2007-3-30 00:21:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT
THANKS
Packing phase:
|  Time  |Packing|  Pressure   | Clamp force|      Status     |
|  (s)   |  (%) |    (MPa)    |  (tonne)   |                 |
|   1.48 |  0.71 |       25.57 |      10.92 |        P        |
|   2.93 |  5.78 |       25.57 |       7.62 |        P        |
|   4.43 | 11.00 |       25.57 |       4.20 |        P        |
|   5.93 | 16.22 |       25.57 |       1.68 |        P        |
|   7.43 | 21.44 |       25.57 |       0.60 |        P        |
|   8.68 | 25.79 |       25.57 |       0.52 |        P        |
|  10.18 | 31.01 |       25.57 |       0.37 |        P        |
|  11.23 | 34.67 |        0.00 |       0.24 |        P        |
|  11.23 |       |             |            |Pressure released|
|  11.63 | 36.05 |        0.00 |       0.18 |        P        |
|  13.13 | 41.27 |        0.00 |       0.00 |        P        |
|  14.38 | 45.62 |        0.00 |       0.00 |        P        |
|  15.88 | 50.85 |        0.00 |       0.00 |        P        |
|  17.38 | 56.07 |        0.00 |       0.00 |        P        |
|  18.88 | 61.29 |        0.00 |       0.00 |        P        |
|  20.13 | 65.64 |        0.00 |       0.00 |        P        |
|  21.63 | 70.86 |        0.00 |       0.00 |        P        |
|  23.13 | 76.08 |        0.00 |       0.00 |        P        |
|  24.63 | 81.30 |        0.00 |       0.00 |        P        |
|  25.88 | 85.65 |        0.00 |       0.00 |        P        |
|  27.38 | 90.87 |        0.00 |       0.00 |        P        |
|  28.88 | 96.10 |        0.00 |       0.00 |        P        |
|  30.13 |100.00 |        0.00 |       0.00 |        P        |
发表于 2007-3-30 15:20:58 | 只看该作者
是产品在保压中重量的百分比
发表于 2007-3-30 23:47:41 | 只看该作者
|  Time  | Volume|  Pressure   | Clamp force|Flow rate|Status |
|  (s)   |  (%)  |    (MPa)    |  (tonne)   |(cm^3/s) |       |
|   0.00 |  0.10 | valve gate =   1  (Elem =    2505 ) opened.|
|   0.15 |  4.96 |        0.73 |       0.00 |    6.09 |   V   |
|   0.30 | 10.03 |        0.84 |       0.00 |    6.09 |   V   |
|   0.47 | 15.43 |        0.92 |       0.01 |    6.10 |   V   |
|   0.62 | 20.49 |        0.99 |       0.01 |    6.10 |   V   |
|   0.78 | 25.72 |        1.05 |       0.02 |    6.10 |   V   |
|   0.91 | 29.90 |        1.11 |       0.02 |    6.10 |   V   |
|   1.07 | 35.19 |        1.20 |       0.03 |    6.10 |   V   |
|   1.21 | 39.81 |        1.30 |       0.04 |    6.09 |   V   |
|   1.37 | 45.16 |        1.44 |       0.06 |    6.09 |   V   |
|   1.52 | 49.77 |        1.53 |       0.08 |    6.09 |   V   |
|   1.66 | 54.41 |        1.65 |       0.10 |    6.10 |   V   |
|   1.80 | 59.03 |        1.76 |       0.13 |    6.10 |   V   |
|   1.96 | 64.20 |        1.89 |       0.16 |    6.10 |   V   |
|   2.11 | 68.81 |        2.02 |       0.19 |    6.10 |   V   |
|   2.26 | 73.68 |        2.16 |       0.23 |    6.10 |   V   |
|   2.42 | 78.89 |        2.31 |       0.28 |    6.10 |   V   |
|   2.56 | 83.36 |        2.47 |       0.33 |    6.09 |   V   |
|   2.70 | 87.91 |        2.65 |       0.40 |    6.09 |   V   |
|   2.86 | 92.86 |        3.07 |       0.58 |    6.09 |   V   |
|   3.01 | 97.47 |        5.06 |       1.56 |    6.07 |   V   |
|   3.06 | 98.90 |        6.70 |       2.62 |    4.81 |  V/P  |
|   3.07 | 99.11 |        5.36 |       2.20 |    2.38 |   P   |
|   3.17 | 99.38 |        5.36 |       2.66 |    0.63 |   P   |
|   3.58 | 99.52 |        5.36 |       2.69 |    0.38 |   P   |
应该是已经注塑的体积
发表于 2007-3-31 12:39:42 | 只看该作者
原帖由 linda_liu 于 2007-3-30 15:20 发表
是产品在保压中重量的百分比
那为什么保压停了以后 百分数还往上涨呢?
GMT+8, 2025-4-29 13:18 , Processed in 0.026681 second(s), 12 queries , Gzip On, Redis On.
