查看: 20539|回复: 29
[灌水] 借我借我一把榔头吧!!
发表于 2007-4-12 20:42:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前几天看到安装E8的投机办法,今天下午试着装了下,第一个跳出来要XP系统才能装,我公司电脑是2000,OK,为了E8我重装系统心甘情愿,装好了XP系统,心想这次总成了吧,,又跳出来个报警,说硬件不符合安装要求,一看才明白,我CPU是AMD的。这次真的是死翘翘了,明天我准备拿把榔头把CPU给砸了,让公司买P4!!
发表于 2007-4-12 20:48:14 | 只看该作者
呵   这世界太疯狂了!!!!!!!!!!!!!!!!!!!!!
发表于 2007-4-12 20:51:35 | 只看该作者
不死真的吧,
发表于 2007-4-12 20:55:01 | 只看该作者
砸CIM公司的人吧.
发表于 2007-4-12 21:42:19 | 只看该作者
我自家的电脑也是AMD,等会儿试装下,千万不要......................
装是装上了,可惜还是要LIC才能用的,可怜了了了
[ 本帖最后由 yyong 于 2007-4-12 22:59 编辑 ]
发表于 2007-4-12 22:20:24 | 只看该作者
我就是用AMD的3800+~~~绝对可以装的上~~
发表于 2007-4-13 09:54:21 | 只看该作者
这是E8的硬件和软件要求
Hardware Requirements
The hardware requirements are described as follows:
•        Processor Pentium 4 or AMD64 (2.4 GHz (or higher)).
•        Pentium III and old AMD computers are not supported. For these computers use a special version; CimatronE 8.0 OC (Old Computer). A message is displayed while installing a standard version on an old computer: "Your hardware (CPU) doesn’t support this installation set of CimatronE. Please use the OC installation set instead. If you do not have it, please contact your local Cimatron Provider."
•        Memory (RAM): minimum 2 Gb (3 Gb recommended)
•        Graphic card: must support OpenGL 3D (with a minimum of 64 Mb)
•        Free Hard disk space: 2 Gb
•        3 button mouse
Notes: For detailed hardware recommendations see Appendices A and B.
Software Requirements
The software requirements are described, as follows:
•        The following operating systems are supported:
•        Windows XP Professional (SP2)
•        Windows XP x64 Edition
•        Operating Systems NT and Server 2003 (SBS 2003) are not supported.
•        Internet Explorer 6 or higher must be installed.
•        It is highly recommended that TCP/IP protocol be installed prior to installing
CimatronE.
•        For computers with Hyper-Threading technology, the user has to set the “Hyper-Threading Technology” parameter to disabled, within the BIOS Setup.
发表于 2007-4-13 09:56:28 | 只看该作者
所以大家要注意一下以上这句话,如果你的硬件达不到要求,你可以装Cimatron E8.0 OC版
发表于 2007-4-13 10:10:04 | 只看该作者
哈哈哈,笑死人了,等吧,等E8的补丁吧
发表于 2007-4-13 11:19:04 | 只看该作者
原帖由 dearbabyer 于 2007-4-13 10:10 发表
哈哈哈,笑死人了,等吧,等E8的补丁吧
没有补丁了,只能装OC版
GMT+8, 2025-2-26 07:26 , Processed in 0.023056 second(s), 10 queries , Gzip On, Redis On.
