查看: 16021|回复: 2
[原创] SolidWorks Beta Program
发表于 2007-4-15 22:01:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
SOLIDWORKS 2008  Beta Program  即将开始。
https://beta.solidworks.com/
SolidWorks Beta Instructions
Reporting Problems
SolidWorks Rx When you encounter a problem in the software, please use SolidWorks Rx to describe and package the issue or question.
1) Use SolidWorks Rx to capture and describe the problem. SolidWorks Rx collects system and SolidWorks configuration information, a description of the problem, a video recording of the session, allows you to attach the SolidWorks files used during the session and then packages the files into a zip archive which can then be submitted via the problem report form. To start SolidWorks Rx, go to Start > All Programs > SolidWorks 2008 > SolidWorks Tools > SolidWorksRx.
2) Review the diagnostics and correct any issues indicated by the utility. Continue to Step 2 - Problem Capture and complete the steps indicated. Include the SolidWorks files if applicable to your issue.
3) When finished, SolidWorks Rx will package all the files in a zip archive. Upload this zip file in step 7 of the Problem Report form listed below.
Problem Report This page is used to create an issue tracking #. The SolidWorks Rx zip package can also be uploaded to give the technical support engineer a complete set of information concerning your problem.
发表于 2007-4-15 22:16:07 | 只看该作者
有中文版的吗?洋文看起来头痛。
要不还是等正式版出来再说吧。
发表于 2007-5-6 00:00:50 | 只看该作者
這麼快又出2008
太強了
GMT+8, 2025-2-10 08:15 , Processed in 0.021074 second(s), 12 queries , Gzip On, Redis On.
