查看: 16774|回复: 0
[转贴] 水波纹渲染效果
发表于 2007-4-27 13:26:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
网上看到的,有兴趣的可以试一下.
Heres a tip to expand upon for your own needs.
If you need to a "water" appearance on objects. Rather then trying to find a static image file, try this..
At a Part/Face/Assy edit level slect SMARTPAINT, Change the following:
Color: Blue
Bump: Burlap (under IronCAD>Images directory)
Bump Setting: 40
You will need ro render to see efeects.
Thats it.
Feel Free to adjust the bump settings to suit.
Hope this helps.
Tom
See Image
GMT+8, 2025-4-18 04:32 , Processed in 0.035809 second(s), 11 queries , Gzip On, Redis On.
