查看: 16484|回复: 3
[求助] 为什么我安装不了E8? 弹出这个窗口!是关于CPU的
发表于 2007-5-22 22:25:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不知道是什么原因!是CPU问题吗?
我的CPU是AMD的   是不是不支持AMD啊?
发表于 2007-5-22 23:36:03 | 只看该作者
需要另一个编译版本.
发表于 2007-5-23 12:37:15 | 只看该作者
是amd什么型号的呀? 我的是3000+ 前年买的 能够用的呀!
发表于 2007-5-23 16:23:57 | 只看该作者
Hardware Requirements
The hardware requirements are described as follows:
• Processor Pentium 4 or AMD64 (2.4 GHz (or higher)).
• Pentium III and old AMD computers are not supported. For these computers use a special
version; CimatronE 8.0 OC (Old Computer). A message is displayed while installing a
standard version on an old computer: "Your hardware (CPU) doesn’t support this
installation set of CimatronE. Please use the OC installation set instead. If you do not have
it, please contact your local Cimatron Provider."
• Memory (RAM): minimum 2 Gb (3 Gb recommended)
• Graphic card: must support OpenGL 3D (with a minimum of 64 Mb)
• Free Hard disk space: 2 Gb
• 3 button mouse
GMT+8, 2025-4-29 10:58 , Processed in 0.021385 second(s), 11 queries , Gzip On, Redis On.
