查看: 17525|回复: 12
【求助】对面的各位高人请看过来!!!!
发表于 2002-4-18 11:12:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在进行结构分析时,出现以下错误提示。请各位高人指点迷津。多谢多谢!!!!!!!
E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANADM                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANBUCK                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANFRQ                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANGUY                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANHEAT                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANLAN                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANLINS                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANNOMO                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANNONL                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANPDI                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANPFLW                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANRDY                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANRESP                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANSUEL                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANSVI                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANTIM                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_ANVAN                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_BUCKLE                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_CLEAN                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_CREF                  E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_IRGD                  E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_MODSOL                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_MPASS                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_NODE0                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_OPTMIZ                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_REDY                  E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_REINIT                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_RENEWC                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_RENEWG                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_RENEWL                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_SHFT                  E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_SNORES                E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_SOLNO                 E  21792 RESERVED VARIABLE NAME ("Y_") NOT VALID - Y_STRSTF
发表于 2002-4-19 13:24:55 | 只看该作者
怎么没有人回答呢?
多多多多多多多多谢了.
发表于 2002-4-22 10:29:21 | 只看该作者
我好好好好想回答,可是我真的。。。。不知道是怎么回事,还是请那位大大来回答吧!
发表于 2002-4-23 09:22:55 | 只看该作者
我以前也出现过类似问题,但后来我发现我的材质没设定好造成的,检查你的材质设定。应该会有帮助的。
发表于 2002-4-24 09:19:13 | 只看该作者
不可能是材料问题,因为这个错误是我在计算无数次中的一次出现的。
发表于 2002-4-24 15:06:39 | 只看该作者
呵呵,是程序的错,我也常莫名其妙的出错的。不过你出错前,作了什么操作?
发表于 2002-4-24 15:17:33 | 只看该作者
我只是修改了一下结点和单元。这不会出错的。我已经修改过nnnnnnn次了。可能是它太累了。要休息了吧!!
发表于 2002-4-24 15:30:31 | 只看该作者
真的是可能的,有时我一个操作,第一次做,给我出来一大堆什么什么。C文件出错什么的。而第二次同样的操作(绝对一样的)它给我做得好好的,有进真想揍它几下,呵呵,有点。。趋向。
发表于 2002-4-26 18:17:13 | 只看该作者
有点象你给定的名字冲突,不能用系统已经保留的名字.
发表于 2002-4-27 10:27:28 | 只看该作者
多谢各位老兄的回答。
GMT+8, 2025-4-29 13:18 , Processed in 0.026890 second(s), 12 queries , Gzip On, Redis On.
