查看: 28571|回复: 45
[原创] 免费制作后处理
发表于 2007-6-14 11:39:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有没有兄弟要后处理的 不管怎样的后处理 我都可以帮你作出来 只要把NC文件给我就可以了!我现在在家待业有的是时间?
我的电话13162638463
邮箱chenwentao83@163.com
发表于 2007-6-14 12:07:39 | 只看该作者
请楼主看看下面改的有无问题?万分感谢!
TOOL CHANGE: FIRST:
      SET_ON  SPIN_SPEED SPIN_DIR ;
*-----save first tool number
      FirstTool = CURR_TOOL ;
      LastTool  = CURR_TOOL ;
*-----tool cutter compensation register number
      CutterComp = CURR_TOOL +  DiaComp ;
*-----assuming 1st tool is in the spindle, there is no need
*     for tool change)
*     OUTPUT $ " T" CURR_TOOL ;
*-----more then one tool in this run of the Post Processor
      IF_SET (NEXT_TOOL _NE_ CURR_TOOL)
         OUTPUT $ " M00 " ;
         OUTPUT $ " (本程式中有2把以上刀具)" ;
      END_IF ;
*-----standard tool change commands. (assuming 1st tool is in
      OUTPUT $ " (文件名称"  PART_NAME   ".pfm)" ;
      OUTPUT $ " ( " CURR_NAME " )" ;
      OUTPUT $ " ( 刀径=" DIAMETER_ " )" ;
      OUTPUT $ " ( R角=" TOOL_RAD ") " ;
      OUTPUT $ " G90 G80 G00 G17 G40 " ;
      OUTPUT $ " Z" Zhome " S" SPIN_SPEED " " SPIN_DIR ;
TOOL CHANGE:
*-----tool change command (by using an internal tool change
*     subroutine)
         OUTPUT $ " M00 " ;
         OUTPUT $ " (以下程式必须用下面的刀具加工)" ;
TOOL CHANGE: LAST:
*-----save last tool number
*     OUTPUT $ " T" CURR_TOOL " M98 P"  ChangeTool ;
*-----the last tool is the same as the first tool
         OUTPUT $ " M00 " ;
      END_IF ;
发表于 2007-6-15 13:36:39 | 只看该作者
老大;帮帮忙了,我现在用的是ug但没有fagor系统的雕刻机的后处理下面是以前处理的,您看一下搞的顶吗?还需要什么东西吗?
%00001
G54
G00 G05 G90 G17
S8000 M03
G04 K500
G51 E0.01
G44
G00
G53 Z-2
G43 D1
G54
X0 Y0
Z20.
X10.2926 Y-46.2506
Z4.015
G01 Z2.955 F1000.
Y42.2306
Y42.2536
G03 X8.5772 Y43.969 R1.7154
X6.8617 Y42.2536 R1.7154
G01 Y-42.2536
G02 X5.1463 Y-43.969 R1.7154
X3.4309 Y-42.2536 R1.7154
G01 Y42.2536
G03 X1.7154 Y43.969 R1.7154
X0. Y42.2536 R1.7154
G01 Y-42.2536
G02 X-1.7154 Y-43.969 R1.7154
X-3.4309 Y-42.2536 R1.7154
G01 Y42.2536
G03 X-5.1463 Y43.969 R1.7154
X-6.8617 Y42.2536 R1.7154
G01 Y-42.2536
G02 X-8.5772 Y-43.969 R1.7154
X-10.2926 Y-42.2536 R1.7154
G01 Y46.2506
G00 Z20.
G17
X23.5037 Y36.9338
Z-5.
G01 Z-6.8 F1000.
G03 X20.5037 Y39.9338 R3.
X17.5037 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-44.6387 R7.705
G01 X-9.7988
G02 X-17.5037 Y-36.9338 R7.705
G01 Y36.9338
G02 X-9.7988 Y44.6387 R7.705
G01 X9.7988
G02 X17.5037 Y36.9338 R7.705
G01 Y34.9338
G03 X20.5037 Y31.9338 R3.
X23.5037 Y34.9338 R3.
G17
发表于 2007-6-15 13:42:43 | 只看该作者
下面是fagor系统的后处理,matercam做的现在用ug 没有后处理不知道您可以搞定吗?
万分感激。。。。。。。。。。。。。。。。。
%00001
G54
G00 G05 G90 G17
S8000 M03
G04 K500
G51 E0.01
G44
G00
G53 Z-2
G43 D1
G54
X0 Y0
Z20.
X10.2926 Y-46.2506
Z4.015
G01 Z2.955 F1000.
Y42.2306
Y42.2536
G01 Y-42.2536
G01 Y42.2536
G01 Y-42.2536
G01 Y42.2536
G01 Y-42.2536
G01 Y46.2506
G00 Z20.
G17
X23.5037 Y36.9338
Z-5.
G01 Z-6.8 F1000.
G01 Y-36.9338
G01 X-9.7988
G01 Y36.9338
G01 X9.7988
G01 Y34.9338
G17
G01 X23.4237 Y36.9338
G03 X20.4237 Y39.9338 R3.
X17.4237 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-44.5587 R7.625
G01 X-9.7988
G02 X-17.4237 Y-36.9338 R7.625
G01 Y36.9338
G02 X-9.7988 Y44.5587 R7.625
G01 X9.7988
G02 X17.4237 Y36.9338 R7.625
G01 Y34.9338
G03 X20.4237 Y31.9338 R3.
X23.4237 Y34.9338 R3.
G17
G01 X23.3437 Y36.9338
G03 X20.3437 Y39.9338 R3.
X17.3437 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-44.4787 R7.545
G01 X-9.7988
G02 X-17.3437 Y-36.9338 R7.545
G01 Y36.9338
G02 X-9.7988 Y44.4787 R7.545
G01 X9.7988
G02 X17.3437 Y36.9338 R7.545
G01 Y34.9338
G03 X20.3437 Y31.9338 R3.
X23.3437 Y34.9338 R3.
G17
G01 X23.2937 Y36.9338
G03 X20.2937 Y39.9338 R3.
X17.2937 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-44.4287 R7.495
G01 X-9.7988
G02 X-17.2937 Y-36.9338 R7.495
G01 Y36.9338
G02 X-9.7988 Y44.4287 R7.495
G01 X9.7988
G02 X17.2937 Y36.9338 R7.495
G01 Y34.9338
G03 X20.2937 Y31.9338 R3.
X23.2937 Y34.9338 R3.
G00 Z20.
G17
X47.4537 Y36.9338
Z-5.
G01 Z-7. F1000.
G03 X44.4537 Y39.9338 R3.
X41.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-68.5887 R31.655
G01 X-9.7988
G02 X-41.4537 Y-36.9338 R31.655
G01 Y36.9338
G02 X-9.7988 Y68.5887 R31.655
G01 X9.7988
G02 X41.4537 Y36.9338 R31.655
G01 Y34.9338
G03 X44.4537 Y31.9338 R3.
X47.4537 Y34.9338 R3.
G17
G01 X43.4537 Y36.9338
G03 X40.4537 Y39.9338 R3.
X37.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-64.5887 R27.655
G01 X-9.7988
G02 X-37.4537 Y-36.9338 R27.655
G01 Y36.9338
G02 X-9.7988 Y64.5887 R27.655
G01 X9.7988
G02 X37.4537 Y36.9338 R27.655
G01 Y34.9338
G03 X40.4537 Y31.9338 R3.
X43.4537 Y34.9338 R3.
G17
G01 X39.4537 Y36.9338
G03 X36.4537 Y39.9338 R3.
X33.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-60.5887 R23.655
G01 X-9.7988
G02 X-33.4537 Y-36.9338 R23.655
G01 Y36.9338
G02 X-9.7988 Y60.5887 R23.655
G01 X9.7988
G02 X33.4537 Y36.9338 R23.655
G01 Y34.9338
G03 X36.4537 Y31.9338 R3.
X39.4537 Y34.9338 R3.
G17
G01 X35.4537 Y36.9338
G03 X32.4537 Y39.9338 R3.
X29.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-56.5887 R19.655
G01 X-9.7988
G02 X-29.4537 Y-36.9338 R19.655
G01 Y36.9338
G02 X-9.7988 Y56.5887 R19.655
G01 X9.7988
G02 X29.4537 Y36.9338 R19.655
G01 Y34.9338
G03 X32.4537 Y31.9338 R3.
X35.4537 Y34.9338 R3.
G17
G01 X31.4537 Y36.9338
G03 X28.4537 Y39.9338 R3.
X25.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-52.5887 R15.655
G01 X-9.7988
G02 X-25.4537 Y-36.9338 R15.655
G01 Y36.9338
G02 X-9.7988 Y52.5887 R15.655
G01 X9.7988
G02 X25.4537 Y36.9338 R15.655
G01 Y34.9338
G03 X28.4537 Y31.9338 R3.
X31.4537 Y34.9338 R3.
G17
G01 X27.4537 Y36.9338
G03 X24.4537 Y39.9338 R3.
X21.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-48.5887 R11.655
G01 X-9.7988
G02 X-21.4537 Y-36.9338 R11.655
G01 Y36.9338
G02 X-9.7988 Y48.5887 R11.655
G01 X9.7988
G02 X21.4537 Y36.9338 R11.655
G01 Y34.9338
G03 X24.4537 Y31.9338 R3.
X27.4537 Y34.9338 R3.
G17
G01 X23.4537 Y36.9338
G03 X20.4537 Y39.9338 R3.
X17.4537 Y36.9338 R3.
G01 Y-36.9338
G02 X9.7988 Y-44.5887 R7.655
G01 X-9.7988
G02 X-17.4537 Y-36.9338 R7.655
G01 Y36.9338
G02 X-9.7988 Y44.5887 R7.655
G01 X9.7988
G02 X17.4537 Y36.9338 R7.655
G01 Y34.9338
G03 X20.4537 Y31.9338 R3.
X23.4537 Y34.9338 R3.
G00 Z20.
M30
发表于 2007-6-15 15:22:47 | 只看该作者
西门子802能钻孔循环的后处理能搞个出来吗,兄弟?现在很想有个,也没有现成的NC文件,或者哪为兄弟有现成的
发表于 2007-6-15 17:42:39 | 只看该作者
+请问有北京精雕的powermill后处理吗?有的话发个给我,小弟在此万分感激!!!!!!QQ271335564
发表于 2007-6-16 20:05:05 | 只看该作者
有没有这样的后处理?
我这里有两台精雕机,一台是法格系统的,另一台是宝元系统的,我现在一台机器分别用它们各自的后处理,不知道大家是否知道,有没有这两种系统的通用后处理,这样我就不用分别出刀路了。谢谢
发表于 2007-6-17 18:15:41 | 只看该作者
小弟有一问题,3D加工后处理都可以,就是有几台西门子802S的2D加工后处理总用子程序处理,机器不支持,可以解决吗?QQ626499380
发表于 2007-6-18 08:47:39 | 只看该作者
7楼的,我有一个适用宝元的。法格就不知道咯,你试同意下咯!
我现在也急需北京精雕的毅雕和上海奈凯系统的后处理,不知哪位大哥有?能否发个给我,小弟在此感激不尽!!!
发表于 2007-6-24 03:48:05 | 只看该作者
我操作的也是一台宝元的,我想试一下你的后处理,可以分享一下吗??
我是个新手,最好把使用的方法给我介绍一下,很笨的我.
感谢!!!!
GMT+8, 2025-2-22 01:50 , Processed in 0.027675 second(s), 13 queries , Gzip On, Redis On.
