查看: 16623|回复: 7
NX5的第一个mp(Maintenance Pack)出现了~~~
发表于 2007-6-16 15:10:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看来新东西问题也有点~~
6月6日,NX5的第一个MP(Maintenance Pack)上传到了UGS FTP
如果装了NX5用着有问题的可以装着看看,不过如果是盗版的话可能会有问题
以下是MP1解决的问题,看看你碰到的问题是不是在里面
Release
PR Number
Problem Description
MP1
1517638
The problem where Part Cleanup sometimes caused an internal error is fixed.
MP1
1528185
The problem where some components were incorrectly positioned when importing a CATIA V5 file is fixed.
MP1
1562533
2076682
5415659
The problem where performing a Save As on a master and its specification (non-master) would result in 2 specification datasets under the same Item Revision if the specification was given a new name in the Save As column of the SaveAs Non-Master part files menu is fixed.
MP1
1578671
The problem where boundary curves at different z-levels caused a crosshatch failure is fixed.
MP1
2080536
The problem where the Insert Sheet dialog did not open when going into Drafting on a new part in the Japanese language environment is fixed.
MP1
2080614
5741146
The problem where 2D Exchange could not export detail views is fixed.
MP1
5405380
5371230
The problem where additional passes were missing in planar mill if zero offset was selected is fixed.
The problem where Planar profiling tool path started in wrong place is fixed.
MP1
5699191
The problem in Assemblies where there sometimes was an error when using the Move Component dialog with faceted bodies is fixed.
MP1
5702932
The problem where Insert Datum CSYS using the Dynamic type produced a CSYS with the wrong orientation when the work part was not the displayed part is fixed.
[ 本帖最后由 lucifer1111 于 2007-6-16 15:12 编辑 ]
发表于 2007-6-16 15:11:38 | 只看该作者
晕倒
还是给外国人看的
发表于 2007-6-16 15:17:16 | 只看该作者
UGS GTAC本来就是全英文的,现在中文官网里的那些中文版的技巧文件都没有了,后悔当初没有下下来
看来换了西门子以后风格果然变了
ps:哪位大大知道怎么申请中文的Newsletter,GTAC里的是英文的…………
[ 本帖最后由 lucifer1111 于 2007-6-16 15:24 编辑 ]
发表于 2007-6-16 15:19:01 | 只看该作者
英文的看一两行还可以
全篇都是可就麻烦了
我装了3.0的cast和帮助文件,也是e文的
不过看着还好
看了好多
发表于 2007-6-16 20:11:30 | 只看该作者
原帖由 mimang 于 2007-6-16 15:19 发表
英文的看一两行还可以
全篇都是可就麻烦了
不过看着还好
看了好多
如果用的是NX4的话就装官方中文版的帮助吧,感觉不错,虽然cast还是英文的
发表于 2007-6-16 22:44:52 | 只看该作者
在哪里下载啊
发表于 2007-6-17 20:22:26 | 只看该作者
在UGS的官方FTP,我正在下载,明天可以贴出EM链接了
大小在109M左右
当然如果你是正版用户而且没有过服务期的话,可以申请webkey直接从官方FTP下载
如果是盗版用户的话请小心,因为目前NX5的破解需要用破解过的文件来覆盖原始文件(我找到的破解来看),所以不知道这次升级是否会影响破解
发表于 2007-7-3 14:10:52 | 只看该作者
到这里下载://moldmakingforum.com
到这里下载:HTTp://moldmakingforum.comHTTp://moldmakingforum.com
[ 本帖最后由 bruceba 于 2007-7-3 14:11 编辑 ]
GMT+8, 2025-4-25 16:12 , Processed in 0.029003 second(s), 12 queries , Gzip On, Redis On.
