查看: 18636|回复: 4
[求助] 后处理 PB_CMD_check_travel_limits
发表于 2007-6-25 10:29:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PB_CMD_check_travel_limits 请问怎么用啊
proc PB_CMD_check_travel_limits { } {
# This custom command may be used to check for the maximum
# travel for each axis.  A warning will be output for each
# GOTO that exceeds the limits.  It does not check for
# parallel axis such as Z and W.  It does not account for
# any modifications done by the user to mom_pos before the
# coordinates are output.
# Import and call this command in PB_CMD_before_motion.
   global mom_sys_max_travel
   global mom_sys_min_travel
   global mom_kin_x_axis_limit
   global mom_kin_y_axis_limit
   global mom_kin_z_axis_limit
   global mom_pos
   global mom_cycle_rapid_to_pos
   global mom_cycle_feed_to_pos
   global mom_cycle_retract_to_pos
   global mom_motion_type
   global mom_warning_info
   if {![info exists mom_sys_max_travel]} {
      for {set i 0} {$i < 3} {incr i} {
         set mom_sys_max_travel($i) $mom_pos($i)
         set mom_sys_min_travel($i) $mom_pos($i)
   } elseif {$mom_motion_type == "CYCLE"} {
         if {$mom_cycle_rapid_to_pos($i) < $mom_sys_min_travel($i)} {
            set mom_sys_min_travel($i) $mom_cycle_rapid_to_pos($i)
         if {$mom_cycle_rapid_to_pos($i) > $mom_sys_max_travel($i)} {
            set mom_sys_max_travel($i) $mom_cycle_rapid_to_pos($i)
         if {$mom_cycle_feed_to_pos($i) < $mom_sys_min_travel($i)} {
            set mom_sys_min_travel($i) $mom_cycle_feed_to_pos($i)
         if {$mom_cycle_feed_to_pos($i) > $mom_sys_max_travel($i)} {
            set mom_sys_max_travel($i) $mom_cycle_feed_to_pos($i)
         if {$mom_cycle_retract_to_pos($i) < $mom_sys_min_travel($i)} {
            set mom_sys_min_travel($i) $mom_cycle_retract_to_pos($i)
         if {$mom_cycle_retract_to_pos($i) > $mom_sys_max_travel($i)} {
            set mom_sys_max_travel($i) $mom_cycle_retract_to_pos($i)
   } else {
         if {$mom_pos($i) < $mom_sys_min_travel($i)} {
         if {$mom_pos($i) > $mom_sys_max_travel($i)} {
   if {[expr $mom_sys_max_travel(0) - $mom_sys_min_travel(0)] > $mom_kin_x_axis_limit} {
      set mom_warning_info "Maximum X axis travel exceeded, did not alter output"
      MOM_catch_warning
   if {[expr $mom_sys_max_travel(1) - $mom_sys_min_travel(1)] > $mom_kin_y_axis_limit} {
      set mom_warning_info "Maximum Y axis travel exceeded, did not alter output"
      MOM_catch_warning
   if {[expr $mom_sys_max_travel(2) - $mom_sys_min_travel(2)] > $mom_kin_z_axis_limit} {
      set mom_warning_info "Maximum Z axis travel exceeded, did not alter output"
      MOM_catch_warning
发表于 2007-6-25 13:46:13 | 只看该作者
发表于 2007-6-25 16:47:06 | 只看该作者
 楼主| 发表于 2007-6-26 09:14:50 | 只看该作者
发表于 2007-7-8 16:48:28 | 只看该作者
GMT+8, 2024-12-5 10:30 , Processed in 0.027278 second(s), 10 queries , Gzip On, Redis On.
© 2002-2024 www.iCAx.org
