查看: 20614|回复: 20
[资料] 国外模具资料奉献之一浇口系列
发表于 2007-6-26 01:50:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
潜伏式和牛角式浇口(英文资料)
Because they extend under the mold parting surfaces, tunnel gates can reach surfaces or features that are not located on the parting line. The gates typically feed surfaces oriented perpendicular to the mold face. Depending upon their design, they degate during ejection or mold opening (see figures 7-33 and 7-34). Tunnel gates that degate during mold opening often require a sucker pin or a feature similar to a sprue puller to hold the runner on the ejector half of the mold. The runner must flex for the gate to clear the undercut in the mold steel.
The gate may break or lock in the mold if the runner is too stiff or if the ejector pin is too close to the gate. Normally,the ejector pin should be at least two runner diameters away from the base of the gate.
The orifice edge closest to the parting line must remain sharp to shear the gate cleanly. When molding abrasive materials such as those filled with glass or mineral,make the gate of hardened or specially treated mold steel to reduce wear. Also,consider fabricating the gate on an insert for easy replacement. The drop angle and conical angle must be large enough to facilitate easy ejection (see figure 7-35). Stiff materials, glass-filled grades for example, generally require drop angles and conical angles at the high side of the range shown in the figure. The modified-tunnel gate design (see figure 7-36) maintains a large flow diameter up to the gate shearoff point to reduce pressure loss and excessive shear heating.
[ 本帖最后由 szlxm123 于 2007-6-26 06:16 编辑 ]
发表于 2007-6-26 06:17:19 | 只看该作者
Curved-tunnel gates permit gating into the underside of surfaces that are oriented parallel to the parting plane (see figure 7-37). Unlike mold fabrication for conventional tunnel gates, the curved, undercut shape of this design must be machined or EDM burned on the surface of a split gate insert. The curved gate must uncurl as the runner advances on guided posts during ejection.
发表于 2007-6-26 15:39:05 | 只看该作者
这样的结构我5年前就会了
发表于 2007-6-27 08:18:59 | 只看该作者
很标准,很好.顶一下
发表于 2007-6-27 10:54:14 | 只看该作者
不错!
发表于 2007-6-28 21:43:38 | 只看该作者
很好,顶下
发表于 2007-7-12 13:09:39 | 只看该作者
学无止境
发表于 2007-8-25 12:34:51 | 只看该作者
顶~~~~`````
发表于 2007-8-26 00:54:34 | 只看该作者
could you please provide the original  file?
发表于 2008-5-3 14:53:33 | 只看该作者
很好。顶一下。
GMT+8, 2025-4-11 15:03 , Processed in 0.030260 second(s), 14 queries , Gzip On, Redis On.
