查看: 62395|回复: 215
[分享] 好书分享:机械公差积累与分析/Mechanica Tolerance Stackup And Analysis
发表于 2007-7-6 12:35:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位关注公差分析的兄弟不要错过啦~
不愿意等待的同志 也可以到上www.goeway.cn去下载
Introduction简介:
Written by one of the foremost authorities in the field, this reference presents proven and easy-to-use methods for determining whether selected dimensioning and tolerancing schemes will yield functional parts and assemblies. The book develops effective problem-solving and analytical skills using a variety of examples and real-world design challenges that stress the importance of a standardized approach to tolerance stackups. Illustrating procedures that have been tested and utilized by leading professionals in industry, this reference demonstrates how to perform "what-if" scenarios to evaluate the effects of changing tolerancing schemes, tolerance values, and assembly sequences.
Every product manufactured today is subject to variation. Typically, the manufacturing process is the source of this variation. From the peaks and valleys of integrated circuits in the microscopic regime to the buttons on
the cell phone in your pocket, to the large steel structures of dams and bridges in the macroscopic regime, no product or part is immune from variation and its sources. Understanding this variation and quantifying its
effect on the form, fit, and function of parts and assemblies are crucial parts of the mechanical design process.
Tolerances are engineering specifications of the acceptable levels of variation for each geometric aspect of a component or assembly. Although tolerances are typically specified on engineering drawings, it is becoming
popular for tolerances to be defined in a CAD file as attributes of a threedimensional solid model. Whether explicitly specified on a drawing or as part of a CAD model, tolerances indicate the variation allowed for part
and assembly features.
Tolerances may be used to control the variation allowed for individual feature geometry, such as form and size, or to control the geometric relationship between part and assembly features, such as orientation and location. Tolerance Analysis and Tolerance Stackups are the tools and techniques used to understand the cumulative effects of tolerances(accumulated variation) and to ensure that these cumulative effects are acceptable.....
Cover封面:
Table of Content目录:
1. Background
2. Dimensioning and Tolerancing
3. Tolerance Format and Decimal Places
4. Converting Plus/Minus Dimensions and Tolerances into Equal Bilaterally Toleranced Dimensions
5. Variation and Sources of Variation
6. Tolerance Analysis
7. Worst-case Tolerance Stackups
8. Statistical Tolerance Stackups
9. Geometric Dimensioning and Tolerancing (GD&T)
10. Converting Plus/Minus Tolerancing to Positional Tolerancing and Projected Tolerance Zones
11. Diametral and Radial Tolerance Stackups
12. Specifying Material Condition Modifiers and Their Effect on Tolerance Stackups
13. The Tolerance Stackup Sketch
14. The Tolerance Stackup Report Form
15. Tolerance Stackup Direction and Tolerance Stackups with Trigonometry
16. Putting it All Together: Tolerance Stackups with GD&T Solved Using the Advanced Dimensional Management Method
17. Calculating Component Tolerances Given a Final Assembly Tolerance Requirement
18. Floating-Fastener and Fixed-Fastener Formulas and Considerations
19. Fit Classifications
20. Form Tolerances in Tolerance Stackups
Notic警告:
Not for commercial use of any kind!
收藏收藏1 分享淘帖 赞一下!赞一下!
推荐
发表于 2007-7-7 14:58:33 | 只看该作者
30-38
推荐
发表于 2007-7-6 15:51:01 | 只看该作者
英文的啊,还是不下了,看不懂啊
发表于 2007-7-6 12:37:50 | 只看该作者
一共63个文件,好就顶一下!
发表于 2007-7-6 13:19:58 | 只看该作者
thank you so much.
发表于 2007-7-6 15:42:44 | 只看该作者
我从www.goeway.cn上,下玩了!!
语句还比较简单,基本可以看明白!!就当学专业外语了!!
发表于 2007-7-6 23:32:15 | 只看该作者
thank you very much!
发表于 2007-7-7 14:56:05 | 只看该作者
20-29
发表于 2007-7-9 07:56:18 | 只看该作者
全E文?!
发表于 2007-7-9 08:20:41 | 只看该作者
知道哪有中文的吗?
GMT+8, 2025-4-26 20:12 , Processed in 0.025811 second(s), 11 queries , Gzip On, Redis On.
